3
[SOLVED] suddenly off
Thread Status:
Not open for further replies.
  1. Sjiya
    Ice Cream Sandwich Feb 12, 2015
    Sjiya , Feb 12, 2015 :
    i entered IMEI number and tired to create the ticket but error " enter order #"
    Ceasedd likes this.
  2. Tobikage
    Nougat Feb 12, 2015
    Tobikage , Feb 12, 2015 :
    What exact error are you getting when you try to install drivers ?
    Ceasedd likes this.
  3. Sjiya
    yes.. even i restore my opo but now its not working after 3-4 mint get hanged and off :(
    Ceasedd likes this.
  4. Ceasedd
    Marshmallow Feb 12, 2015
    Ceasedd , Feb 12, 2015 :
    Also turn off gestures if those are on they'll wreck havoc together with buggy MX 's pinch and swipe that might be your problem .I don't like mx's accelerators
  5. ParamK.
    Moderator Moderator Feb 12, 2015
    ParamK. , Feb 12, 2015 :
    Check your order number in your account on Amazon. In
    Ceasedd likes this.
  6. Sjiya
    QHSUSB_BULK no driver found
    Ceasedd likes this.
  7. Ceasedd
    Do you still have the overheating problem or just your phone shutts off after a few min?
  8. SoniaB
    Community Hero 2020 Feb 12, 2015
    SoniaB , Feb 12, 2015 :
    @Sjiya do you have another laptop computer you could borrow/use?
    @sarangsharma - there are a lot of us posting at the same time. To avoid cross posting and confusing OP anymore, are you happy to help Sjiya and take it forward 1-2-1?
    Mydealz, Darko87, PVS Kharoud and 2 others like this.
  9. Sjiya
    i have order number but option enter order number is disable
    Ceasedd likes this.
  10. nishanth_k
    Honeycomb Feb 12, 2015
    nishanth_k , Feb 12, 2015 :
    Restart the phone and try to uninstall the MXplayer.
    Ceasedd likes this.
  11. ParamK.
  12. ParamK.
    Ceasedd likes this.
  13. nishanth_k
    If the phone is shutting down every 5-10 minutes is it safe to flash ? Contact customer support.
    Ceasedd likes this.
  14. Sjiya
    i have factory reset already
    Ceasedd likes this.
  15. Sjiya
    Ceasedd likes this.
  16. Sjiya
    \no i don't have :(
    Ceasedd likes this.
  17. Ceasedd
    My last advice ,your phone will shutt off if not fully charged less than 30% ,battery might need recalibration ,let your phone loose its charge completely plug it in a let it charge to 100% (phone off while charging)
    Darko87, SoniaB and Tobikage like this.
  18. Sjiya
    no more overheating after few mints if i touch it and want to use it, its get hanged and turn off
    Ceasedd likes this.
  19. ParamK.
    Depends on your Windows. Check which one is it x86 or x64
    Ceasedd and Tobikage like this.
  20. Andoenay
    Gingerbread Feb 12, 2015
    Ceasedd likes this.
