sound distortion with notifications
  1. daddycool
    Gingerbread Dec 8, 2017
    daddycool , Dec 8, 2017 :
    hi guys,
    I am experiencing a problem with notification sounds.
    I think it's only happened since the recent update...,
    when I get a notification the sound is pretty low and crackles like a distortion or interference.
    I've gone to the notification sounds in the settings and gone through the notification choices of sounds and it does it on all of them.
    so then I've tried some music mp3 tracks and it seems to work fine so I carnt see this being my speaker faulty.
    I cleared the cache after I updated the recent update just incase someone was to ask.
    has anyone else been experiencing this?
    cheers
    Abdulhamud likes this.
  2. daddycool
    I've restarted the device and cleared cache again and I think it's cleared this issue now.
    I don't understand why it did this in the first place it sounded like my speaker was dieing
  3. lukaash
    Eclair Dec 9, 2017
  4. ankeshgoyal05
    Donut Dec 10, 2017
    ankeshgoyal05 , Dec 10, 2017 :
    I'm facing the same issue, tell me what to do, this problem is going crazy
  5. daddycool
    Gingerbread Dec 10, 2017
    daddycool , Dec 10, 2017 :
    I just went to recovery and cleared the cache and restarted and it's not done it again. its obviously a software glitch. I thought my phone was faulty at first haha but I can assure you it isn't.
  6. ankeshgoyal05
    Donut Dec 10, 2017
    cool, thanks I'll just try it out
  7. ankeshgoyal05
    Donut Dec 10, 2017
    still facing the issue, by recovery cache you mean app cache right
  8. FaleshC
    KitKat Dec 10, 2017
    FaleshC , Dec 10, 2017 :
    by recovery means
    shut down your phone and hold power button + volume down together until you see oneplus logo.
    be careful what you do if you don't know about recovery, select wipe and then advanced only select CACHE nothing else.
    it will ask you to confirm and then Reboot after its done.
  9. Abdulhamud
    Cupcake Dec 24, 2017
    Abdulhamud , Dec 24, 2017 :
    i faced the exact problem .. it's just with the notifications sounds right ? the music and videos working well with you ?
  10. F1529648814145
    Cupcake Nov 8, 2018
    F1529648814145 , Nov 8, 2018 :
    After updating the latest software notifications sound during calls has got really distorted.
    It is crushing the ears too much.
    Plz make it same as before.
  11. benm7896
    Froyo Nov 8, 2018
    benm7896 , Nov 8, 2018 :
    I am also getting the distortion on notifications this has happened on my phone and also through android auto.
  12. AhmedMaher93
    Donut Mar 9, 2020
