sound in headphones 3.5 Jack shit (((fix it ;-(
  1. siberian22rus
    Donut Jun 3, 2018
    siberian22rus , Jun 3, 2018 :
    Yes, it can only be fixed by the developer. Hopefully this will happen sometime like Mi Max. Thank you.
    #41
  2. MentalDraco
    Marshmallow Jun 3, 2018
    MentalDraco , Jun 3, 2018 :
    Naaa I can barely go past half before my ears start to hurt from the volume, the 5T is way too loud.
    #42
  3. siberian22rus
    Donut Jun 3, 2018
    can you give me your mixer_paths_tasha.xml from 5T?
    #43
  4. MentalDraco
    Don't you need root for that ?
    #44
  5. ouyamaster
    Honeycomb Jun 3, 2018
    ouyamaster , Jun 3, 2018 :
    I didn't bother with any of this. When my head phone volume was too low on external speakers I just used exkernel to raise my volume from odb to 20db. yes exkernel from flar2 requires root. Exkernel manager is available for I think 5 bucks in okay store and is the most user friendly custom kernel you can find. The different volumes can be found under sound.
    #45
  6. siberian22rus
    Donut Jun 3, 2018
    I have a root. I have now downloaded and tried this mixer_paths_tasha.xml (stereo mod) and it had an effect. I do not know which values are responsible for the sound level of the headphones. Change each and reboot for a very long time.
    #46
  7. ouyamaster
    Here is the sound control manager in Exkernel. I used the headphone digital gain to make my headphone output louder. turning it to 20db while connected to external speakers. Just be careful to lower the volume rocker when you raise the gain. I also set it back to default when not using external speakers. Make sure you read and understand how exkernel works before trying this. The other speakers besides the headphones can also easily be controlled here but I cannot verify if they work because my issues was with the headphone speakers when physically connected to external speakers with a sound cable.
    siberian22rus
    to difficult read up on exkernel manager and kernel. you will get user friendly control knobs for the speakers.
    #47
  8. MentalDraco
    Yes but I'm not rooted, that's what I wanted to say .
    Anyways my player has amplifier function.
    #48
  9. siberian22rus
    Donut Jun 3, 2018
    #49
  10. MentalDraco
    BlackPlayer, mine is the EX payed version, not sure if the free one has it enabled. Guess you can check. But BlackPlayerEx payed was like 20 cents last I checked.
    #50
    siberian22rus likes this.
  11. anupritaisno1
    KitKat Jun 3, 2018
    anupritaisno1 , Jun 3, 2018 :
    You're not a guru of sound.
    #51
  12. ouyamaster
    What you are saying might work but exkernel manager has a control for each of the speakers. I use exkernel for wake gestures so I already had it.
    #52
  13. siberian22rus
    Donut Jun 3, 2018
    searched for a long time, but could not find the sound settings.
    #53
  14. ouyamaster
    Sound is under gestures on the US version. Not sure what it's under in your language but it should be there.
    #54
  15. siberian22rus
    Donut Jun 3, 2018
    Yes, I see you have it. You can determine by the icons, the language need not be known. I do not understand a thing. Do you have 1 + 5? Firmware I have the latest beta. Why do not I have this item, strange.
    #55
  16. ouyamaster
    Not sure at all but after the recent update after rerooting I just go to exkernel section and update. install or update the kernel. just don't flash on top of another custom kernel only op5t stocked kernel is safe. if you have a different custom kernel read up on how to dirty flash the stock rom. the zip file for current op5t should be in download section of one plus.com. if you have stock kernel just flash exkernel through exkernel manager exkernel section.
    #56
  17. siberian22rus
    Donut Jun 3, 2018
    dude, it worked out! [e]263a[/e]️[e]1f44f[/e][e]1f44d[/e] I updated the kernel inside the program and the settings appeared. I thought that no one would do better than Viper.
    And the black player is also cool! [e]263a[/e]️ In the free version everything is open too.
    #57
    ouyamaster likes this.
  18. LilLewis
    LilLewis , Jun 3, 2018 :
    viper4android is so bad lol
    #58
  19. O1518232242294
    Cupcake Jun 3, 2018
    O1518232242294 , Jun 3, 2018 :
    how to do that ?
    #59
  20. siberian22rus
    Donut Jun 3, 2018
    For complete happiness, it would be good to know where the headphone level settings are here?
    #60
