Sound Latency in PUBG
  1. Kingisher_0078
    Cupcake Aug 2, 2020
    Kingisher_0078 , Aug 2, 2020 :
    I jus got my OP WBZ and facing sound latency issue in fanatic Mode also. I have bought this only to play PUBG as OnePlus mention low latency for OP device but i dont think low latency work actually. I have reset the earphone also but same issue.
    Device: OP 5
  2. B_Wrath
    Nougat Aug 2, 2020
    B_Wrath , Aug 2, 2020 :
    Is it really hard for you guys to read the notes in the product page before buying?
    And this has been answered way too many times on the forum. Please do a basic search instead of creating a thread.
  3. Kingisher_0078
    Cupcake Aug 2, 2020
    So you mean to say latency will be there? Or do we have any solution for this.. And may be my forum will help if anyone thinking to buy it.
  4. Waveform Modifier
    Marshmallow Aug 2, 2020
    Waveform Modifier , Aug 2, 2020 :
    Hahahahahahahahaha... Very funny.
    You know what really helps? Not make redundant thread.
    B_Wrath likes this.
  5. B_Wrath
    Nougat Aug 2, 2020
    Please read the product page once. Especially the notes given below.
    Kingisher_0078 likes this.
  6. _Aditya_Jain_
    Honeycomb Aug 2, 2020
    _Aditya_Jain_ , via OnePlus 5T , Aug 2, 2020 :
    Low latency mode is only supported on OnePlus 6 or newer devices.
    But given that you had only purchased this headset for gaming, you should have gone with a wired headset.
  7. Kingisher_0078
    Cupcake Aug 3, 2020
    Kingisher_0078 , Aug 3, 2020 :
    Thanks aditya.. Jus now i have read the Notes properly... And oneplus doesn't have return policy either... My bad.. Any fix by which i can make it work with OP 5 as well..?
  8. _Aditya_Jain_
    Honeycomb Aug 3, 2020
    _Aditya_Jain_ , via OnePlus 5T , Aug 3, 2020 :
    I am not aware of any workaround for this.
    _AyushiJain_ likes this.
  9. _Aditya_Jain_
    But even with the low latency mode, you will never be able to get the audio performance of a wired headset while gaming.
  10. Teekar.2023
    Gingerbread Aug 5, 2020
    Teekar.2023 , via OnePlus 5T , Aug 5, 2020 :
    If you read carefully or did any sort of research whatsoever like a Google search, you would know that the low latency mode is only for OnePlus 6 and newer using fnatic mode.
