Speaker Issue during Phone Calls via OnePlus 7 Pro
  1. NEOMERCER
    Froyo Mar 13, 2021
    NEOMERCER , via OnePlus 7 Pro , Mar 13, 2021 :
    I'm having an issue with my 7 Pro. It's currently running the Oxygen OS 11 beta 3 software (it's skipped 2 for some reason) and at certain times when making and receiving calls the phone will sound like it's in a very quiet speaker mode setting. I can hear the caller coming from the bottom speaker when I should only be hearing them from the earpiece. Likewise, I thought while using speaker phone that only the bottom speaker made noise but when I switch that on occasionally both speakers will make noise. I'm not sure why this is or if it was always supposed to be like this. I was going to report this issue in traditional fashion, but I didn't want to add my phone number and all that extra stuff that is required.
  2. Artemus.
    Community Hero 2020 Mar 13, 2021
    Artemus. , Mar 13, 2021 :
    Beta problems belong in the beta thread.
    Aaron2017, J4t1np4r3kh and drl431 like this.
  3. NEOMERCER
    Froyo Mar 14, 2021
    NEOMERCER , via OnePlus 7 Pro , Mar 14, 2021 :
    Then link? I looked for it and didn't see it. Unless it's just the same Beta announcement thread.
  4. Aaron2017
    KitKat Mar 14, 2021
    Aaron2017 , Mar 14, 2021 :
    It's the same open beta 3 announcement thread. You can submit proper feedback and your logs here
    https://forums.oneplus.com/feedback
    NEOMERCER likes this.
  5. NEOMERCER
    Froyo Mar 14, 2021
    Aaron2017 likes this.
  6. Aaron2017
    KitKat Mar 14, 2021
  7. #7
  8. Tperkins
    Donut Apr 23, 2021
    Tperkins , Apr 23, 2021 :
    Someone on another part of this forum said "Stop HearingAidService under Bluetooth running services in Developer options under system. I had the same issue. Hearing aid services are being turned on without Bluetooth being on." I had the same issue and could not fix it, so I downgraded from OOS 11 to 10. So I cannot try it but it seems low risk to try. All credit is to user K1557852550059
