2
[Submitted] speaker issue
  1. G_mohammed_sameer_VRSv
    Cupcake Sep 27, 2019
    G_mohammed_sameer_VRSv , Sep 27, 2019 :
    hi my mobile bottom speaker not working properly it stopped working sometimes and when I restart it's working again. Please help me with this issuy
    chaitanyakoribilli and nayak17 like this.
  2. nayak17
    Cupcake Oct 29, 2019
  3. F1573282761359
    Cupcake Nov 9, 2019
    F1573282761359 , Nov 9, 2019 :
    even I am facing the same issue, although it gets resolved when you reboot the phone, still the issue is coming again and again.
  4. yubraj014
    Cupcake Nov 21, 2019
  5. G1575980465269
    Cupcake Dec 10, 2019
  6. junnu_2008
    Cupcake Dec 18, 2019
  7. U1576857517527
    Cupcake Dec 30, 2019
  8. #8
  9. J1581713774551
    Cupcake May 7, 2020
    J1581713774551 , via OnePlus 6T , May 7, 2020 :
    If you are on a OP 6/6t it's normal, only the left speaker works, the other one will never work, no matter if you restart the phone or do anything else.
    The other speaker was added only for simmetry/aesthetic.
  10. A1568961545969
    Cupcake May 9, 2020
  11. #11
  12. X1590374348610
    Cupcake May 25, 2020
    X1590374348610 , via OnePlus 7 Pro , May 25, 2020 :
    I m also having speaker issue. the main speaker stops working and only the speaker near ear piece is working which have very low sound ... always need to reboot to fix it...
    singhakshay786 likes this.
  13. shkshbz
    Donut Jun 4, 2020
    shkshbz , via OnePlus 7T Pro , Jun 4, 2020 :
    Yes its same issues for me, I do not know how to solve it, only reboot is the solution, but it started for me when I started using wired earphone on my 7t pro. After using them mobile gets in call mode, so only earpiece works and speaker doesn't. Is this the same issue for all?
  14. anwar9540e
    Cupcake Jun 5, 2020
    anwar9540e , Jun 5, 2020 :
    I'm having this same problem. The speaker goes to earphone suddenly and phone needs to be restarted. Having this problem for more than a month. Please give a solution asap
  15. O1593547519640
    Cupcake Jun 30, 2020
