3
Sound
Speaker Problem
  1. Amal Xavier Eclair Mar 15, 2015
    Amal Xavier, Mar 15, 2015 :
    When i played a video there was no sound in bottom speaker and upon checking it the sound was coming from ear piece only but in a minimum Volume . then i restarted my phone then it was ok . Can you please tell me the reason .
  2. rikardo1979 Lollipop Community Expert Mar 15, 2015
    rikardo1979, Mar 15, 2015 :
    no without going into log and you would need to have debugging on beforehand
    but your issue is resolved with reboot so no need to investigate anymore
    X1535048391854 likes this.
  3. Amal Xavier Eclair Mar 15, 2015
    So will that problem come again .. and why did that happen . I use headphone and that's not one plus one's headphone . is that the problem
  4. uawan Ice Cream Sandwich Mar 15, 2015
    saadsid11 likes this.
  5. fatfingers Honeycomb Mar 15, 2015
    fatfingers, Mar 15, 2015 :
    They cannot tell you, that, which they do not know.
    Your restart worked for you, this time.
    What about the next time sound malfunctions?
    Hope restart works again, for your sake.
    If not, don't expect help from rikardo 1979.
    "your issue is resolved with reboot
    so no need to investigate anymore"
    You are not alone.
    Here's some reading for you:
    https://productforums.google.com/forum/#!topic/nexus/qJRGKkh4xX0
  6. Renata Raw Cupcake Mar 15, 2015
  7. abhimuktheeswarar Honeycomb Mar 28, 2015
    abhimuktheeswarar, Mar 28, 2015 :
    I got the same problem more than 3 times randomly, for no reason. & bcoz of that, I missed important calls ! >.
    Even they it resolves after a reboot. What if it happens again & I miss the phone calls ?
    Its very bad
    kotzurr likes this.
  8. mohammed.ab91 Gingerbread Mar 28, 2015
    mohammed.ab91, Mar 28, 2015 :
    I had once the same problem.. I'm having issues with microphone while on call.. Other person can't hear me properly. :(
    All started with latest update. Until then I had no issues. The worst is when there's some problem with basic functionality of a phone.
    Waiting for lollipop, hope the issue gets resolved
  9. rikardo1979 Lollipop Community Expert Mar 28, 2015
    rikardo1979, Mar 28, 2015 :
    try to disable OK Google function, this seems to fix the issue when your voice is distorted for caller on other side
  10. sharatgangwani Eclair Mar 28, 2015
    sharatgangwani, Mar 28, 2015 :
    What do you mean by no need to investigate more? I'm having the same problem frequently and restarting all the time is not the solution. This has happened overnight which led to missed alarms. This is definitely a bug in the software that needs to be fixed
    KlyveCruz and farman86 like this.
  11. lostLambda Lollipop Mar 28, 2015
  12. mohammed.ab91 Gingerbread Mar 28, 2015
    I'll try that
  13. yanik11 Cupcake Mar 28, 2015
  14. mohammed.ab91 Gingerbread Mar 31, 2015
    mohammed.ab91, Mar 31, 2015 :
    I guess it worked out. :)..
    Speaker output coming out from earpiece. I faced this issue again when I used whatsapp call feature.. I had put on speaker during the call. Later when I played music, the sound was coming from earpiece. I called one my friends again from whatsapp(not in speaker this time), it was resolved then.
  15. Knightshiner Ice Cream Sandwich Aug 26, 2015
    Knightshiner, Aug 26, 2015 :
    Hey I also had similar problem , bottom speakers were not working but after the restart they started working. It clearly seem to be a software problem.
    Its such a shame one plus is ignoring such problems. @Carl please resolve these minors chinks in otherwise a great phone.
    G_saumya_sharma_lgTJ likes this.
  16. brkrishna Cupcake Apr 22, 2016
    brkrishna, Apr 22, 2016 :
    I am facing the similar issue since last 5 days. The sound is not coming out of speakers but coming from ear piece. Restarting phone every time is really painful. :(
    Isn't there any solution for this??
    One thing I observed is when this issue starts, on pressing volume up or down buttons it is showing Call Volume instead of speaker volume.
    See even though I increase or decrease volume it is happening for call volume but not speaker volume.
    Please find a solution for this.
  17. nash859 Jelly Bean Apr 22, 2016
    brkrishna likes this.
  18. mushytitan Eclair Apr 22, 2016
    mushytitan, Apr 22, 2016 :
    So I was not the only one! I made a thread asking the same thing. I kinda liked it, ya know having "front facing speakers" but it ended up fixing itself. What version of android are you on? I am on COS 13.0 incremental.
  19. brkrishna Cupcake Apr 23, 2016
  20. aboelseoud Eclair Sep 1, 2016
