Speaker sound reduced via OnePlus 7
  1. cr1411
    Froyo Apr 14, 2021
    cr1411 , via OnePlus 7 , Apr 14, 2021 :
    After the update, I was facing issue with speaker volume it is reduced!Intially it was loud enough,now it is somewhat reduced
  2. KaranFafat
    Honeycomb Apr 14, 2021
  3. cr1411
    Froyo Apr 14, 2021
  4. Akshat Sehgal
    Gingerbread Apr 14, 2021
    Akshat Sehgal , via OnePlus Community App , Apr 14, 2021 :
    Could be because of dust trapped in your speaker grill. Clean it out using an earbud/Q-Tip but be very careful. You can also dip a new Q-Tip in some isopropyl alcohol to get rid of the small pieces of dirt. Don't use access of alcohol as it can damage your speaker and your phone too.
    If that doesn't work, try downgrading. You can search for "downgrading package" here in the forum itself.
    Further, you may report it here: https://forums.oneplus.com/feedback/
  5. rayprayas03
    Ice Cream Sandwich Apr 15, 2021
    cr1411 likes this.
  6. InamKhanzzz
    Donut May 17, 2021
