Spellchecker does not work.
  1. Tej_Sapkota
    Cupcake Mar 16, 2018
  2. Tej_Sapkota
  3. The1Lion
    Marshmallow Mar 16, 2018
    The1Lion , Mar 16, 2018 :
    For me, only if it's not already installed. Under the Add On dictionaries:
  4. The1Lion
    That's the personal one so you could add words that would normally be indicated as a misspelled word but are actually correct. For instance " Oneplus" is considered a misspelled word but if you select "Add to dictionary" it should show up in your personal dictionary.
  5. G_Viru
    Jelly Bean Mar 16, 2018
  6. Tej_Sapkota
    Tej_Sapkota , Mar 16, 2018 :
    There is no "Add on dictionary option"
  7. Tej_Sapkota
    Did that. Spell Checker still only works on factory version of app.
  8. The1Lion
    That's probably the problem then. When you hold the "," (on the keyboard) and get the gear to select "Input Options" then select Android Keyboard Settings (AOSP), Text Correction - there should be Personal Dictionary and then Add-on dictionaries. It's really the "Add-on dictionaries" that have all the words for spell checker. The personal one is just words you add. I'll upload a screen shot in a minute...
  9. Tej_Sapkota
    Here is how it looks.
  10. The1Lion
  11. Tej_Sapkota
    If you turn that on, you get a strip at the top with word suggestions but the red line does not appear. I toggled that option multiple times. Still no red line. I then disabled it as I find the suggestion bar annoying.
  12. The1Lion
    Just noticed you also have auto correction off- turn that on and it should work - Actually I should say IF you mistype a word and then space, does the line appear? The line doesn't appear right away with auto correction off, but should if you press space and have a misspelled word.
  13. Tej_Sapkota
  14. The1Lion
    Interesting. I had GBoard a while back but didn't reinstall when I moved to LOS and I'm still running 14 so not on Oreo yet. You're Oxygen version is updated to Oreo? I did reinstall the GBoard and played with settings and tried to match what you have show but spell check still worked no matter what.
  15. Tej_Sapkota
    I got this shipped from china so I initially had hydrogen OS. I guess something went wrong when I switched it :/. I downloaded the file from OnePlus official site, cleared cache, reset my phone before doing it. Idk what seems to be the problem.
  16. The1Lion
    Marshmallow Mar 19, 2018
    The1Lion , Mar 19, 2018 :
    Did you ever get this working? @MentalDraco this is the thread I was referring to. Same issue, GBoard not doing the spellcheck with the underlines.
    MentalDraco likes this.
  17. MentalDraco
    MentalDraco , Mar 19, 2018 :
    I probably have seen it, but the problem did not manifest at that time, ty for the heads up. I'll stick to swiftkey till the next Gboard update and see if it still behaves the same.
    The1Lion likes this.
  18. Tej_Sapkota
    Cupcake Mar 19, 2018
    Tej_Sapkota , Mar 19, 2018 :
    Nope. Updating the app still means spellchecker does not work. I'll wait for the next update as well.
    #38
