3
Split-screen issue after Android 10 update?
  1. Ang3lisM
    Donut Nov 17, 2019
    Ang3lisM , Nov 17, 2019 :
    Not sure if it's just me or some of you guys might be experiencing this problem. Ever since the Android 10 update, I can no longer double-tap the recent button to activate split-screen with the 2 most recent apps. now when I double-tap the button, all it does is turning into the split-screen logo and nothing happens. I have to single tap the recent button, go to the top right corner and choose the split-screen option to activate it. I tried resetting the device, that didn't fix the issue. very strange. o_O
    ABEDOMRAN, janek and suraj1595 like this.
  2. Zackeroo
    Gingerbread Nov 18, 2019
    Zackeroo , Nov 18, 2019 :
    Hop into Buttons & Gestures, then Navigation bar & Gestures, then Navigation bar customization, then tap on 'Double tap action' for the Recents Button and choose 'Open/Close split screen'
    This should work perfectly fine :)
    Let me know how it goes... If it helped you out a like would be appreciated :)
    Ang3lisM likes this.
  3. Ang3lisM
    Donut Nov 18, 2019
    Ang3lisM , Nov 18, 2019 :
    that's exactly what I did:p but the issue is still there. I just found out yesterday, the function only works when I have one app open. o_O
    Zackeroo likes this.
  4. Zackeroo
    Zackeroo , via OnePlus 7 Pro , Nov 18, 2019 :
    What do you mean 'One App Open'?
    Do you mean nothing running in the background? Because that is really weird [e]1f602[/e]
  5. D1573731009012
    Cupcake Nov 20, 2019
    D1573731009012 , Nov 20, 2019 :
    Split-screen is awesome. I've got a Nexus 6 and I use it every day.
    A couple months back Facebook messenger stopped supporting it and I just kinda rolled my eyes, that apps been getting worse for years and I've mostly moved to WhatsApp anyway, and there's always those 'bubbles' as a workaround.
    Then Inbox stopped supporting it...why? There's no reason I can't write an email while I've got a YouTube video playing. Then today Reddit is fun has been updated and guess what...'this app doesn't support split-screen', oh that's cool, it only did for the last 2 years, why not just scrap usability for no reason I suppose.
    Like...do app developers not want me to use their apps? Why take away usability and functionality? I watch YouTube videos while I'm scrolling Reddit, now I can't do that? Is there an app I can get to 'force' split-screen?
    fedloan irs.gov easybib
    I'm assuming it's being taken away because of something to do with usage statistics and getting users to focus on one app at a time, at least, I hope there's a reason. Can anyone enlighten me or feels similarly? And I know I've got an older phone running an older OS so I don't know if that's a part of it.
  6. Ang3lisM
    Donut Nov 23, 2019
    Ang3lisM , via OnePlus 7 Pro , Nov 23, 2019 :
    yes. nothing in the back ground [e]1f602[/e] I think the phone is bugged. now I can't get lte every time I switch from Wi-Fi. it takes hours for it to find lte network.
  7. Zackeroo
    Gingerbread Nov 23, 2019
    Zackeroo , via OnePlus 7 Pro Mirror Gray , Nov 23, 2019 :
    Yea that's weird. You could try a software update and hope that fixes the issues... otherwise, you warranty will cover the issues
  8. Ang3lisM
    Donut Nov 23, 2019
    I'm not sure. I hope the next software update will fix both the splitscreen and lte problem. this is my second OP7 pro already. [e]1f602[/e] the first one I got had a damaged camera housing. I think it's just bad luck for me, kept getting lemon phones. [e]1f62d[/e]
  9. Zackeroo
    Woww. Yea it's just really bad luck for you [e]1f602[/e][e]1f602[/e]
    This is my first *OnePlus* and I have to say that I am probs never gonna switch back to another brand after using this [e]1f602[/e][e]1f602[/e]
  10. AbedabbadoO
    Cupcake Nov 27, 2019
    AbedabbadoO , Nov 27, 2019 :
    I have the same issue! Out of the box (Android Pie) hold recent for split screen worked great, but since updating to Q, it no longer functions properly. After holding recent, the icon changes to the split screen icon, but I need to hit the back button twice for the recent menu to appear under my running app in split screen mode.
    I did notice that switching to navigation gestures then back to "back, home, recent" sometimes gets it working again, but rarely.
    You can see from the screenshot the split screen button, but one one app open.
    Glad I'm not the only one, but would really like a fix...
  11. suraj1595
    Honeycomb Dec 14, 2019
    suraj1595 , Dec 14, 2019 :
    Wow.. yes same here !!! Not and to double tap to open split screen in conventional 3 button navigation bar..
    Did you find any solution?
  12. suraj1595
  13. Ang3lisM
    Donut Dec 14, 2019
    Ang3lisM , via OnePlus 7 Pro , Dec 14, 2019 :
    after the update recently, mine seemed to just fixed itself. I'm gonna test it out for a bit and see if it's consistent.
    suraj1595 likes this.
  14. janek
    Eclair Dec 16, 2019
    janek , Dec 16, 2019 :
    I have the same issue with my OnePlus 6. Also after updating to Android 10 (beta channel). Seems to be an issue in OxygenOS for Android 10...
  15. Powan33
    Cupcake Jan 9, 2020
    Powan33 , via OnePlus 6 , Jan 9, 2020 :
    The problem is know for Android
    it is the home who block the function
    I have the problem on go launcher and Nova
    I switch to oneplus launcher default....It work
    I hope i have help you
  16. Powan33
    Cupcake Jan 9, 2020
    Second trick it work when you use recent screen
    at top right you have 3 dots.
    With splittables applications appears in menu "Split screen" mention
    Tested, it work.
    Sorry if my english id not good
  17. W1577296322014
    Cupcake May 25, 2020
    W1577296322014 , May 25, 2020 :
    Facing the same issue in op7t also changed view in the recent tabs and not showing three dots in the corner. Please suggest solution how to enable split screen
    yogikale15 likes this.
  18. Artemus.
    Nougat May 25, 2020
    Artemus. , May 25, 2020 :
    Long-press card, menu shows up. Boom.
  19. AbedabbadoO
    Cupcake May 26, 2020
    AbedabbadoO , May 26, 2020 :
    This is still a problem in Android 10. I can also confirm that it occurs with all 3rd party launchers and is not an issue for the stock OnePlus Launcher. See below for a video:
    http://imgur.com/a/bX19Fm4
    A fix for this, or at least acknowledgement of the bug from OnePlus would be greatly appreciated.
  20. Artemus.
    Nougat May 26, 2020
    Artemus. , May 26, 2020 :
    Um... you're not even holding the right thing down. The card needs to be held down, not the Recents button. The card is the app preview that you cycle through.
