Split Screen navigation gesture
  1. Shivam Bhatia
    Donut Aug 23, 2019
    Shivam Bhatia , Aug 23, 2019 :
    If i use navigation gestures instead of on screen buttons, then to go into split screen we have to go to multitask than we can choose the option to split screen.
    This causes the current app(like YouTube) to stop for a while causing the video to stop.
    Where as if I use the on screen buttons to go into split screen it doesn't stop the app, which is good.
    So please help in getting a navigation gesture for that or provide the option in quick settings.
    Thanks and Regards.
    Q1564980445577 likes this.
  2. Coolhandz
    Eclair Aug 26, 2019
    Coolhandz , Aug 26, 2019 :
    you can tap on whatever app and use gestures like normal. for example: i have YouTube on top and maps on the bottom. i just tap the YouTube portion and use gestures from the bottom of the device. you do not need to open task manager.
