Spotify low volume issue
  1. arashhsh
    Honeycomb May 12, 2015
    arashhsh , May 12, 2015 :
    Hi Guys,
    I have a problem, when I listen to Music with the Spotify app my sound wont get that much volume as when im using the stock mediaplayer (googleplay music) does some one know a fix for this?
    I like to use Spotify because im a lazy ****** and adding songs to my playlist is easier with Spotify than downloading.
  2. DaxNagtegaal
    Marshmallow May 12, 2015
  3. arashhsh
    Do I have to Do that? Isn't it Just weird it does that... I shouldnt have to unlock bootloader or whatsoever
  4. KrishPlusOne
    Jelly Bean May 12, 2015
    KrishPlusOne , May 12, 2015 :
    I dont know about google play music, but i did have something like this.. For me volume was down everywhere. I tried a factory reset and things worked fine after that.
    PS: H/W decoder wont work when this issue perisists.
    arashhsh likes this.
  5. arashhsh
    Alreaddy did a factory reset but it didnt help
  6. KrishPlusOne
    If you have MXplayer, can you see if H/W decoder works??
  7. DaxNagtegaal
    DaxNagtegaal , May 12, 2015 :
    It's a good idea to unlock it either way
    Spotify has always been iffy with volume for me
  8. Wackencorpse
    KitKat May 12, 2015
    Wackencorpse , May 12, 2015 :
    I got the same problem and an unlocked bootloader. Can you tell how to solve this problem?
  9. UnknownSoul
    UnknownSoul , May 12, 2015 :
    I thought it sounded odd myself. Compared and I have this same problem as well. Guess I'll stick to using my iPhone for music for now until I can fix it.
  10. UnknownSoul
    Jelly Bean May 21, 2015
  11. Wackencorpse
    KitKat May 22, 2015
    Wackencorpse , May 22, 2015 :
    I don´t know. I´ll update spotify later and tell you if the problem is fixed or not.
  12. Wackencorpse
    KitKat May 22, 2015
    Ok, downloaded the update and I think it is fixed for the moment. I hope the will not unfix it with one of the next updates...:p
