Spotify Not work in One Plus 7 via OnePlus 7
  1. SyedTabishHasan
    Cupcake Jun 30, 2020
    SyedTabishHasan , via OnePlus 7 , Jun 30, 2020 :
    When I Open Spotify or Spotify Light It do not Work if I am using it with normal Data Connection . It shows No Internet connection available. If I am using Wifi than it works cool . This is a problem with One Plus as I have already contacted to get this resolved from Spotify
  2. the_o2
    User of the Year 2018 Jun 30, 2020
    the_o2 , Jun 30, 2020 :
    Press and hold the app
    Click on app info
    Mobile data and Wi-Fi
    check whether the ' Disabled DataUsage' is enabled if so then disable it.
