5
Spots on back panel
  1. GauravPathak26
    Donut Jul 7, 2020
  2. abidbunny
    Honeycomb Jul 7, 2020
  3. GauravPathak26
    Donut Jul 7, 2020
    GauravPathak26 , via OnePlus 7T , Jul 7, 2020 :
    This is the first time OP disappointed me, even i thought it's because of my fault the spots came out but there are so many people out there with the same complain.
  4. GauravPathak26
    Donut Jul 7, 2020
  5. djorghios
    Eclair Jul 9, 2020
    djorghios , Jul 9, 2020 :
    it's different bro, yess the 5/5t metal surface getting scratches due to dust particles. but this 7t back panel is not scratches due to dust. if dust causing this there will be no Black color spot. its happen on sticker color under the glass
  6. CaptJackSparr0w
    Gingerbread Jul 9, 2020
    DX__13 likes this.
  7. DX__13
    Cupcake Jul 9, 2020
    gaurav27jul likes this.
  8. Suvarna24
    Donut Jul 11, 2020
    Suvarna24 , Jul 11, 2020 :
    Even me facing d issue ,any solution for dis problem.does dey replace under warranty
  9. szofdani
    Eclair Jul 26, 2020
    szofdani , via OnePlus 7T , Jul 26, 2020 :
    I had this problem in the 7t, 7t pro for which I bought the spingen case, if this case was publicized, maybe oneplus would do something about it
    Edithstark likes this.
  10. TumulNigam
    Froyo Jul 27, 2020
    TumulNigam , via OnePlus 7T , Jul 27, 2020 :
    Glass is glass and each &every phone with a glass or matte back panel faces shows up these types of spots. I had bought my device last year aeound december ,since then i clean its back glass every week, so i have very minor spots on it till date!!!🙃🙃🙃
  11. djorghios
    Eclair Jul 28, 2020
    djorghios , Jul 28, 2020 :
    the problem is the spot is underneath the glass which is we can not do anything to clean it. mine also clean it every once in a week
  12. DEVGHOST10
    Gingerbread Jul 28, 2020
    DEVGHOST10 , via OnePlus 7T , Jul 28, 2020 :
    IhaveaOnePlus
    So how can we resolve this​
    you live in humid area.? this coated back phones wont respond well to the humid atmosphere...most probably its a fungus growth due to humidity
  13. DEVGHOST10
    DX__13 likes this.
  14. DEVGHOST10
    Trapped internal heat and atmospheric humidity causes this issue...had this for oneplus 6t now 7t too
    djorghios likes this.
  15. DEVGHOST10
    cases traps the heat...keep the phone open or chose the case which gives phone a bit room to breathe..for now this is the best option to prevent this or go to the service center to resolve
  16. Number_Six
    Froyo Oct 16, 2020
  17. Edithstark
    Gingerbread Oct 16, 2020
    Edithstark , via OnePlus 7T , Oct 16, 2020 :
    The spots are caused because of the low quality sticker which is applied on the glass to give it the color. Its fault of oneplus and this case should get to them as there are thousands of 7ts facing this issue. Don't try to put it on the user as they are not scratches but discoloration of the sticker. We should stick together and try to get oneplus to do something about it rather than fighting about whose fault is this
  18. Suvarna24
    Donut Oct 18, 2020
    Suvarna24 , via OnePlus 7T , Oct 18, 2020 :
    It's true oneplus should help us else it is not our fault.....
    #38
  19. Attached Files:
    #39
    Suvarna24 likes this.
  20. Suvarna24
    Donut Apr 26, 2021
    #40
