3
Battery/Charging Standby battery drain problem
  1. fahad_maniar
    Gingerbread Feb 5, 2017
    fahad_maniar , Feb 5, 2017 :
    I'm quite happy with my SOT (7-8 hrs avg) but the phone discharges 4-5% every night and sometimes more..btw i only have my wifi on at night and i think the battery drain shouldn't be so much when the phone is idle.. Btw i have the developer doze mode on (aggressive off) and i use greenify..my phone is in deep sleep most of the time but still the battery drain is there..Do you have any tips or suggestions to reduce the battery drain? Thanks for your help in advance.
  2. amitssj
    Honeycomb Feb 5, 2017
    amitssj , Feb 5, 2017 :
    How is the network signal range? If it is low it might drain your battery to fetch strong signal, but as u said 4-5% battey drain is ok for 6 hours.
  3. F_Tony_DeMartino_hjHI
    Ice Cream Sandwich Feb 5, 2017
    amitssj and Kiran.a.joseph like this.
  4. Master_TC
    KitKat Feb 5, 2017
    Master_TC , Feb 5, 2017 :
    I would say everythink sounds normal. Look into the battery stat. What drains the battery over night?
    Kiran.a.joseph likes this.
  5. rajon007
    Eclair Feb 5, 2017
  6. simon_remotedpictures
    Eclair Feb 5, 2017
  7. jmichaelvaldez
    Cupcake Feb 5, 2017
    jmichaelvaldez , Feb 5, 2017 :
    Been following the myth of the 40-80 charging rule, but decided to charge my 3t to 100% before work to get a better gauge of the battery life. Not so good so far, first 20% drained with only 30mins of SOT.
  8. fahad_maniar
    The network is fine in my area. I get full network coverage so that's not a problem. I dunno i think its a bit on the higher side.. Maybe that's just me.. Do you experience the same drain?
  9. fahad_maniar
    Can you tell me how to check what drains the battery overnight? Gsam n other battery stats give the total battery drainage if i'm not wrong..is there a way to only check whats draining the battery when the phone is idle?
  10. fahad_maniar
    That's rough man..maybe because of snapchat? I dont use it so i cant tell.. Try clearing your cache and also the google play services data and then reboot.. I've heard it helps improving battery life
    Crazsped likes this.
  11. Kartikeya agarwal
    Donut Feb 5, 2017
  12. Huntlaar
    Cupcake Feb 5, 2017
  13. fahad_maniar
    How much does your battery drain overnight?
  14. Oomaar
    Oomaar , Feb 5, 2017 :
    everyone of us has that same problem and there's nothing you can do 'bout it unless you root your phone and underclock the processor. the other only solution is the OnePlus has to fix it.
    well by the way, my phone never drain all in just 5hours except last last which i used all the time and I had it for 7hrsSOT, the other times the battery lasts 24hrs.
  15. airiartev
    Jelly Bean Feb 5, 2017
  16. fahad_maniar
    Gingerbread Feb 6, 2017
    fahad_maniar , Feb 6, 2017 :
    Ummm..No i don't. Why?
  17. msvr
    Honeycomb Feb 6, 2017
    msvr , Feb 6, 2017 :
    your's is way better, mine to was like that dropping a percent per hour/two.. but recently it's like 3%/hour
  18. msvr
    i leave it overnight to see around 24% drop even without wifi/data
  19. GiulioMecacci
    Eclair Feb 6, 2017
    GiulioMecacci , Feb 6, 2017 :
    mine just dropped 20% overnight. There is no trace of assessable wakelocks. I have installed nothing but a few of the most common apps. Don't know what to do. First days it was a monster, now it barely stays alive. It is one month old.
    fahad_maniar likes this.
  20. fahad_maniar
    20% omg..Hearing from you guys.. I think i dont have a right to complain with 4-5% :| i hope oneplus fix this in their next update or smth..it shouldn't drain so much when the phone is literally not doing anything
    Crazsped and dineshsp04 like this.
