7
Display Static (tv snow) screen
  1. schlaxel
    Cupcake Dec 25, 2017
    schlaxel , Dec 25, 2017 :
    Uneblieveable. Same problem, same solution. I was almost in tears :D
    Thank's a lot for sharing!
  2. Marti9t9
    Cupcake Dec 31, 2017
    Marti9t9 , Dec 31, 2017 :
    Thank you so much. Think my issue was slightly different in that screen would show snow only SOME of the time. Connector must've barely been loose Daughter knocked my phone off the sofa. . Thank you thank you thank you. Love this phone. Would have been devastated.
  3. tiancar
    Cupcake Jan 12, 2018
    tiancar , Jan 12, 2018 :
    Mate you are a god! Happened to me and i pressed and it started working again. Thank you so much :D
  4. AntonFrom
    Cupcake Feb 10, 2018
    AntonFrom , Feb 10, 2018 :
    Happened to my girlfriends OnePlus 3T this morning when it fell out of her pocket indoors and we sorta panicked because we're going on vacation in just a couple days so there wasn't time for sending it for repair. But after slapping its backside firmly into my open palm a couple of times it worked as new again (didn't read past the first couple posts before I tried so can't say where it "popped back"). Thank you all!
  5. wonie
    Cupcake Feb 11, 2018
    wonie , Feb 11, 2018 :
    thank you so much i put a little pressure around my screen and it LIVESSSS AGAINN!!! This is awesome, i owe you T_T
  6. MVB_OnePlus
    Cupcake Mar 5, 2018
    MVB_OnePlus , Mar 5, 2018 :
    Thank you so much LadyR0uge. I just dropped my OnePlus3 and this got my screen to work again. You are amazing.
    -M
  7. Joe13134453
    Gingerbread Jun 15, 2018
    Joe13134453 , Jun 15, 2018 :
    It's the connection for the monitor to the motherboard that is coming loose, happened to mine popped the screws out and opened it up, snapped the connector back in place. You could also squeeze right below the dual SIM tray and probably get the same result.
  8. ericosg
    Cupcake Jul 1, 2018
  9. Bajebimmer
    Cupcake Aug 15, 2018
    Bajebimmer , Aug 15, 2018 :
    Just had same issue, phone dropped and all I saw was snow. Turned off pressed screen in several areas turned on and it worked.
  10. Bublion
    Cupcake Aug 27, 2018
    Bublion , Aug 27, 2018 :
    I can`t believe I tried this, but saved me as well :D I am really thankful for this community forum!
  11. X1539591188644
    Cupcake Oct 15, 2018
    X1539591188644 , Oct 15, 2018 :
    Same problem, just a google led to this page and it instantly works! But what is the exact technical problem here? Someone from OnePlus care to answer?
  12. Punk_69
    Lollipop Nov 1, 2018
    Punk_69 , Nov 1, 2018 :
    @BeingIncog i came to this thread ..... press all around the screen, and screen seems to work, but dunno how long it'll last....
    BeingIncog likes this.
  13. hmvs
    Cupcake Dec 25, 2018
  14. elanglois
    Lollipop Dec 25, 2018
    elanglois , Dec 25, 2018 :
    Warranty doesn't cover abuse
    Remove two screws from bottom. Remove SIM tray. Remove back cover using plastic tool (carefully!). Reattach ribbon cable and make sure it's firm. This will be the one on the far bottom right side of the motherboard. Reassemble
  15. JavierL
    Froyo Jan 1, 2019
  16. kolipakam
    Cupcake Feb 28, 2019
  17. dandjon
    Cupcake May 31, 2019
    dandjon , May 31, 2019 :
    Thanks so much. I dropped my phone this morning and was on the verge of tears when I saw the "tv snow" screen. Then I saw your solution. I pressed it and it sorta worked; the display came back but was frozen. I didn't want to keep pressing or press too hard for fear I would finally break it, then I saw an additional response that recommended slapping the back of it. WOOOHHOOOO!! Problem solved. Had I not seen your response, I would've paid unnecessarily (and maybe expensively) for a repair.
    I fell in love with this phone from the moment it reached my hands. This phone is the best. I'm a oneplus-er for life.
  18. Cher1
    Cupcake Jun 7, 2019
    Cher1 , Jun 7, 2019 :
    I'm having the same issue and I just replaced the screen less than 2 weeks ago . Did anybody else's phone look like this and got it the display to work ?
    #38
  19. G_sivji_sivjik_hGZw
    Cupcake Jun 13, 2019
    G_sivji_sivjik_hGZw , Jun 13, 2019 :
    Thanks a lot, saved a load of money....
    #39
    SLSwenson likes this.
  20. SLSwenson
    Cupcake Aug 13, 2019
    SLSwenson , Aug 13, 2019 :
    Slapping the phone or squeezing around the edges of the screen works for me to get rid of the grey-screen or snow-screen problem, but it only works for a while, like a few hours to a day. Also, after I've brought back the screen through one of these methods, the touch response doesn't work as well as it should.
    Has anyone had this professionally fixed? If so, what was the repair, and how much did it course? And of course, did the fix keep working for a long time?
    Thanks in advance, community!
    #40
