OxygenOS Steady notification led on OP6
  1. Mario_Coda
    Cupcake Sep 11, 2019
    Mario_Coda , Sep 11, 2019 :
    One of the things I loved most about my previous OPs was the ability to customize the frequency of the notification led (super slow / slow / fast / super fast / steady).
    For me the best was steady led, not intermittent led. On OP6 this is no longer possible. Is there a way to do this?
  2. teachmeluv
    Eclair Sep 11, 2019
    teachmeluv , Sep 11, 2019 :
    Maybe its for technical reasons as this is the last Oneplus device which has a notification led.
  3. Mario_Coda
    Okay, but since it actually have a notification led... maybe there's a way to customize it.
  4. jasemanONE
    Gingerbread Sep 11, 2019
    jasemanONE , Sep 11, 2019 :
    Did you try any of the apps that are available from the Play Store that are designed to manipulate the LED?
    I used to use them all the time in days past with rather good success, but I prefer to use native apps when possible and I am satisfied with the way it works as it is. YMMV
  5. Mario_Coda
    Cupcake Sep 12, 2019
    Mario_Coda , Sep 12, 2019 :
    Me too. I hope someone has the solution...
