Still problem downloading from play store. After updated to 4.0.1
  1. Dhairya.Bhatt
    Eclair Jan 8, 2017
    Dhairya.Bhatt , Jan 8, 2017 :
    I have updated the 4.0.1 os but still problem downloading app from play store with jio 4g network.. i have try all the steps which give in post. Google trouble shoot problem solbe steps also tried uninstalling true caller and paytm then cheaked aps and all settings. But still not solve problem.
    So plz givee solution for that.
    I have used one plus 3
    #never settle
  2. Android450
    Marshmallow Jan 8, 2017
  3. G_Kleant_Cupi_fLGd
    Donut Jan 8, 2017
  4. Vjetaa
    Cupcake Jan 8, 2017
    Vjetaa , Jan 8, 2017 :
    Go to quick settings and make sure you are not using anyVPN.
    I can't download from play store while using (block this!) VPN.
    Solves the problem for me.
  5. singhk89
    Froyo Jan 8, 2017
    _Chaitanya_Chugh_1998 likes this.
  6. singhk89
    Froyo Jan 8, 2017
  7. singhk89
    Froyo Jan 8, 2017
    singhk89 , Jan 8, 2017 :
    you need to install open beta10 and then do a clean install in order to set things back.
  8. RONY JOHN
    Gingerbread Jan 8, 2017
    RONY JOHN , Jan 8, 2017 :
    Please copy all ur files to ur pc and do a fac reset for christ sake.That ll solve ur problem. U ll also get F2FS partition by doing so.
  9. Vishal kp
    Vishal kp , Jan 8, 2017 :
    I've done the reset twice it will work fine for few hours or a day but the again the problem continues. Uninstalling the Truecaller worked for me,now it's working fine.
    Android450 likes this.
  10. Android450
    Android450 , Jan 8, 2017 :
    ah well glad you were able to find a fix
  11. G_anirban_khamaru_WgPL
    Cupcake Jan 8, 2017
    G_anirban_khamaru_WgPL , Jan 8, 2017 :
    wtf!!!! just uninstall the truecaller... problem solved bt why l!!! what is in Truecaller!!! no idea... and thanks bro @ vishal
  12. F_Avin_Raj_gckf
    Cupcake Jan 8, 2017
  13. _Chaitanya_Chugh_1998
    Cupcake Jan 8, 2017
  14. _Chaitanya_Chugh_1998
    Cupcake Jan 8, 2017
  15. a5pe4
  16. Soumik2k19
    Soumik2k19 , Jan 8, 2017 :
    reset the phone...i have encountered the same problem. after a full reset it worked for me now the phone works fine...
  17. Zh_kilat
    Android Q Jan 8, 2017
    Zh_kilat , Jan 8, 2017 :
    Nougat problem ....
  18. Narender
    Eclair Jan 8, 2017
    Narender , Jan 8, 2017 :
    I was also facing but if u have installed Truecaller / pytm /Antivirus unistall these it will work
  19. Dhairya.Bhatt
    Eclair Jan 8, 2017
  20. SanjayTakkar
    Cupcake Jan 14, 2017
    SanjayTakkar , Jan 14, 2017 :
    I solved my play store problem very quickly and easily ,
    it's very simple just go to Play Store...
    setting and activate Parental Control, as I activate Parental Control Play Store start downloading !! no need to uninstall paytm or truecaller.. .
