Stock Recovery pattern not working
  1. isthatxavier
    Honeycomb May 16, 2017
    isthatxavier , May 16, 2017 :
    I have enabled "require pattern when turning on", and when booting into recovery I am being asked to draw the pattern and my pattern is not being accepted. It loading bar goes green not even half way then it turns red and phone vibrates and the same draw-pattern screen comes up.
  2. G_Abrar_Ansari_xBeu
    Froyo May 16, 2017
    G_Abrar_Ansari_xBeu , May 16, 2017 :
    happend with me... i didnt find any solution for tht...thts y i kept pin instead of pattern nd it works perfectly fine
  3. adhish_np
    Honeycomb May 17, 2017
    adhish_np , May 17, 2017 :
    that's a big, had experienced the same and did a factory reset
    this guy has a solution if you are open TWRP
  4. adhish_np
  5. Prowhiz
    Prowhiz , May 17, 2017 :
    Happened to me. The reason is because in your pattern, there's a part where you draw across a certain dot twice. like a cross or intersection. I found out it is recognized for unlocking the lockscreen but not when booting. Try programming a different unlocking pattern where you don't draw over a dot twice. Or just use a pin. It's more secure that way anyway.
  6. G_ivan_valencia_fZFQ
    Donut May 17, 2017
