7
Stop complaining about battery issues!
  1. andreasgunster4
    Froyo Jan 30, 2017
    andreasgunster4 , Jan 30, 2017 :
    I have a OnePlus 3t and I receive none of the rampant battery issues that everyone on this forum always seems to be complaining about. I thought I'd provide some tips. First off, uninstall Facebook, it drains a ton of battery, use a third party alternative. Secondly, turn on aggressive doze, it works wonders.
  2. AlphaCygni
    Honeycomb Jan 30, 2017
    AlphaCygni , Jan 30, 2017 :
    Meh. I'm quite sure that there are plenty of 3T's with defective batteries/boards out there and nothing can't really be done beside replacing the phone.
    My words are based on owning an original OP3 which runs the very same apps and usage pattern and has much better power conaumption. My 3T acts like it has only 2500-2600mah battery in it.
    Jalaj94 likes this.
  3. G_abdullah_jokhdar_lTlY
    Cupcake Jan 30, 2017
  4. csemnani
    Gingerbread Jan 30, 2017
    csemnani , Jan 30, 2017 :
    Never get close to that. I'm at 54% right now and sot says 1hr20min. Usually get albetween 2 and 3 hours. I wonder how people are getting such long sots
    Jalaj94 and G_Sumanth_Samig_MoES like this.
  5. [email protected]
  6. [email protected]
    [email protected] , Jan 30, 2017 :
    do you always keep WiFi, Bluetooth or internet carrier data on?
  7. G_matt_neill_FwkB
    G_matt_neill_FwkB , Jan 30, 2017 :
    who are you to tell people to stop complaining!just because you get awesome battery doesn't mean everyone else does!if people have a problem they post it on the forum an it just so happens battery life is by far the biggest problem on the latest updates!I'm pretty sure people have tried all those basic things that u have suggested the problems run a lot deeper
  8. csemnani
    All always on. What's the point of turning them off. I have a Fitbit that needs to sync with the phone. I thought when you are on strong wifi, the data kind of turns off.
  9. Deactivated User
    Jan 30, 2017
    Jalaj94 likes this.
  10. F_Jacky_Koli_FZOZ
    Donut Jan 30, 2017
    andreasgunster4 likes this.
  11. G_Sid_Gog_gucx
    G_Sid_Gog_gucx , Jan 30, 2017 :
    It monitor and calculate average power consumption from user usage pattern. If device is running heavy app from day 1 then it will show time that's shorter but realistic.
  12. amitssj
    amitssj , Jan 30, 2017 :
  13. amitssj
    You can try enabling Doze mode in Developer options, that really juice up the battery and give u more SOT :)
  14. Wahoux
    Lollipop Jan 30, 2017
    Wahoux , Jan 30, 2017 :
    A lot of people don't know how use a smartphone, that's why they have battery drain...
    andreasgunster4 and vintagetech like this.
  15. ritchiedrama
    Ice Cream Sandwich Jan 30, 2017
    Ultra.Numan likes this.
  16. F_Edina_Pap_ycRr
    Donut Jan 30, 2017
    F_Edina_Pap_ycRr , Jan 30, 2017 :
    oh really? so that's why my phone on MM lasted for about 4 days, and now on Nougat IT drains like hell, thank you for solving everyone's issue!
    Chrisnik and Jalaj94 like this.
  17. HoriaRave
    Froyo Jan 30, 2017
    HoriaRave , Jan 30, 2017 :
    There is no faulty batteries or bords, the short SOTs are down to the apps you have on the phone, how you use the phone and the draining bugs that the software has.
    Everyone can get to 4.5-5 hours SOT.
  18. Dubzlondon
    Eclair Jan 30, 2017
  19. Dunnow
    The Lab - OnePlus 6 Reviewer Jan 30, 2017
    Dunnow , Jan 30, 2017 :
    Good, another of those threads with an opener in denial that since he is not affected by an issue it seems to not even exist at all.
    I'll use my dumb example so lower IQ people can understand.
    I'm not hungry, therefore, there's no hunger in the world.
    Do you see the flaw in that logic?
    There we go then.
    Have a nice day if you have battery issues, have an horrible day if you do not.
    Peace.
  20. Wahoux
    And for me, no change between MM and N... 4-5h SOT
