7
STORAGE ISSUE IN NORD 2 via OnePlus Community App
  1. VIVEK_singh09 , via OnePlus Community App , Jul 30, 2021 :
    Camera app show SD CARD ERROR and Whatsapp show turn off USB storage
    And some app closes automatically when it use any storage
    Google map also closes automatically.
    If someone has facing same issue let me know.
  2. taterminala , via OnePlus Community App , Jul 30, 2021 :
    I have the same issue, I received my Nord 2 5g today and after updating it and configuring all my apps and accounts the camera start crashing with SD Error, Whatsapp in dual mode tells me that there was no storage and most of the apps crash without any message.
    Please I need help.
  3. VIVEK_singh09 , via OnePlus Community App , Jul 31, 2021 :
    Have you try factory reset?
    O1627553944820 likes this.
  4. #4
  5. V1627648901176
    Donut Jul 31, 2021
  6. #6
  7. #7
    V1624366298835 likes this.
  8. V1624366298835
    Cupcake Jul 31, 2021
  9. gthing2264
    Froyo Jul 31, 2021
    gthing2264 , Jul 31, 2021 :
    Same issue here with app clone, maps and camera.
    This phone is not fit for the purpose it's intended. Is it possible to get a refund after the box has been opened?
  10. VIVEK_singh09 , via OnePlus Community App , Jul 31, 2021 :
    Just uninstall the app cloner .then restart your device.
    gthing2264 and O1627553944820 like this.
  11. O1627553944820
    O1627553944820 , Jul 31, 2021 :
  12. O1627553944820
    I am also faced same "SD error Camera is temp unavailable" while is using other office apps when app cloner whatapp enabled and its solved when I "delete whatsapp app cloner" and reset camera and restart phone .. Finally App dual whatsapp cloner is not working which need to fix it by one plus
  13. O1627553944820
    "App cloner" whatsapp not supported for nord 2.. One plus team what is the solution else process to return this phone​
  14. O1627553944820
    App clone not supporting nord2 once it deleted my current issue have been solved
  15. #15
  16. O1627553944820
    You can return go amazon app
  17. O1627553944820
    You can return from 7 day from the delivery check if you purchase from amazon apps
  18. O1627553944820
    Return within 7 days from the purchase go to amazon apps and return
  19. #19
  20. Y1627463100041
    Y1627463100041 , Jul 31, 2021 :
    I actually found the problem: It only happened while I was using my Whatsapp Clone.
    As soon as I uninstalled the Clone App of Whatsapp the problem no longer occured.
