Strange behaviour for Tele Photos
  1. choiwah
    Eclair May 17, 2021
    choiwah , May 17, 2021 :
    There are two photos taken from a similar scene but at different times with the Tele Mode. The Exif are very similar.
    1. ISO 200, f/2.4, 1/100s, 7.4mm, 5:30pm
    2. ISO 200, f/2.4, 1/74s, 7.4, 5:57pm
    The first picture contains much much more detail than the second one. The second one just seems blur out. It seems the cam wasn't using the same lens at all. 1.png 1-1.png 2.png 2-1.png
  2. Sheppards
    Jelly Bean May 17, 2021
    Sheppards , via OnePlus 7T , May 17, 2021 :
    From experience, if there is not enough ambient light, the phone will use the main camera for zoom, and will crop an image from the main sensors essentially using digital zoom
  3. choiwah
    Eclair May 17, 2021
    choiwah , via OnePlus 9 Pro , May 17, 2021 :
    the tele lens is disappointed....
  4. rasta_firasta
    The Lab - OnePlus 9 Pro Reviewer May 17, 2021
    rasta_firasta , via OnePlus 9 Pro , May 17, 2021 :
    As per your mentioned exif data ..both images are taken from Telephoto lens ( check the aperture). As I can see, there is gap in time of both images ( almost 30mins) Reason of not getting details in second image is ambient light.
    Bobbie63 and McJader like this.
  5. choiwah
    Eclair May 18, 2021
    choiwah , May 18, 2021 :
    Both images have the same ISO Level ISO200. Normally, it should NOT have two different noise level and noise-cancelling setting under the same ISO Level. The sunset here is approx 7pm. The light didn't change dramatically, as you can notice both images have the same ISO, Aperture & focal length, but a different exposure time 1/100 vs 1/74.
    I tend to believe that the second one is a cropped image from Main Camera.
  6. choiwah
    Eclair May 18, 2021
