Strange issue when applying UV glue for glass screen protector via OnePlus 8 Pro
  1. WhaTheF
    Froyo Jul 6, 2020
    WhaTheF , via OnePlus 8 Pro , Jul 6, 2020 :
    So I have installed a UV glue tempered glass screen protector about 3 times now, 2 from the same manufacturer and one from a different one on my OP8Pro
    One each, almoat exactly at the same spot on my screen i get a rainbow/bubble & micro-bubble patch when the glue spreads (it shrinks after several minutes but some bubbles remain) .
    Is this an issue with my screen? Missing/rubbed-off oliophobic coating?
    I never used my screen without some kind of screen protector so not sure how this might happen.
    Any one had similar issue?
    666Syco likes this.
  2. cssrc1974
    Jelly Bean Jul 6, 2020
  3. anesh007
    Ice Cream Sandwich Jul 6, 2020
  4. #4
  5. A1591880373878
    Cupcake Jul 12, 2020
  6. #6
  7. Vaisakh_Kc
  8. WhaTheF
    Froyo Jul 12, 2020
    WhaTheF , via OnePlus 8 Pro , Jul 12, 2020 :
    Didn't notice any effect on the front camera and didn't see any uv glass that comes with a hole.
    In my opinion it's worse with a hole since it attracts dust and dirt that just gathers in the hole.
    Vaisakh_Kc likes this.
  9. 666Syco , via OnePlus 8 Pro Ultramarine Blue , Jul 13, 2020 :
    I have the same issue and I have 2 OnePlus 8 Pro's. bought multiple brands of tempered glass and I've used Whitestone Loca from a pixel 2 XL kits (spare/leftovers) tubes of Loca. What I do is Cure just the top of the tempered with the UV lamp and then I lift the bottom with an angled squeegee made of hard plastic. once I lift it and it rests back down and the bubble dissipates leaving very minimal bubbles, if any. Pain in the ***, but it works.
    WhaTheF likes this.
