Stuck at Bootloader is unlocked screen, my power button doesn't work!
  1. Divyanshu_Sankhwar
    Gingerbread Jun 21, 2021
    Divyanshu_Sankhwar , Jun 21, 2021 :
    Hi All,
    After using A10 for almost 2 years I decided to finally decided to try A11 before A12 comes out.
    I flashed PE recovery(Pixel experience) from fastboot and send fastboot reboot command, post which I am stuck at 'bootloader is unlocked' screen. My power button doesn't work, so I can't go to recovery or fastboot from here, also cannot pause the boot. Phone is not detectable from ADB or Fastboot.
    What to do now?
    Please HELP
  2. Divyanshu_Sankhwar
    Gingerbread Jun 22, 2021
    Best Answer
    Divyanshu_Sankhwar , Jun 22, 2021 :
    Thanks for the help, I waited for the phone to discharge, when I plugged the charger in I was able to see charging animation.
    I pressed Vol down button for 15 sec(No power button) and was able to boot into PE recovery, post that It was a breeze.
    Sideloaded the copy partition zip and flashed the rom.
  3. ItsRavi25
    Jelly Bean Jun 22, 2021
