stuck in headphone mode on lollipop
  1. bertbosi Froyo May 15, 2015
    bertbosi, May 15, 2015 :
    For most user that have this problem they get a solution usually. I tried different solutions, reset, upgrade, downgrade, and install from scratch the hole system but no success. Anyone who can help is welcome. Should I open a ticket to OnePlus One team?
    Thanks in advance.
    Glad to be here folks
  2. rez1_k Ice Cream Sandwich May 15, 2015
    rez1_k, May 15, 2015 :
    Shine a light into your headphone port and see if any of the contacts are bent or broken. If you're not sure what you're looking for, try to take a photo of said port and upload it here. Someone can take a look and compare it their own to inform you if something looks out of place.
    Good luck.
    bertbosi, Tobikage and LostPorcupine like this.
  3. Tobikage Nougat May 15, 2015
    Tobikage, May 15, 2015 :
    Ever damaged the headphone jack ? moisture ?
    like @rez1_k said Look for any visible damage or any other debris inside...
    Since you've tried all the other software based solutions , dont see any other way...ticket it is..
    BTW ...does the jack work when you plug it in ??
    milkdude and rez1_k like this.
  4. milkdude KitKat May 15, 2015
    milkdude, May 15, 2015 :
    Funny but could be pocket lint,trapped between the contacts. Had it happen before.
    Tobikage likes this.
  5. bertbosi Froyo May 15, 2015
    Nope it does not work
  6. Tobikage Nougat May 15, 2015
  7. O1563901914551 Cupcake Jul 23, 2019
    O1563901914551, Jul 23, 2019 :
    Hi there, I've the same issue.. I was out when I got heavily drenched and I got this problem after that. not sure what to do. but I've cleaned the port. no more moisture. but still problem persists. please help
