Other stuck in recovery/fasstboot
  1. zab2x3z
    Cupcake Feb 8, 2021
    zab2x3z , Feb 8, 2021 :
    i tried to install the beta using OxygenUpdater but my oneplus is now stuck at boot and since i have not turn on usb debbuging i'm not able to do anything is there some way i cant just flash the stock firmware?
  2. lucas.requile
    Eclair Feb 8, 2021
    lucas.requile , Feb 8, 2021 :
    If a reboot doesn't fix it, put the zip image on a USB flash drive and connect it via an OTG cable. You should be able to flash it this way.
  3. zab2x3z
    Cupcake Feb 8, 2021
    how can i flash it from a flash drive witouht a custom recovery installed?
  4. lucas.requile
    Eclair Feb 8, 2021
    lucas.requile , via OnePlus 7 Pro , Feb 8, 2021 :
    Boot into recovery mode by turning the phone off, and turning it on nu holding the power down and volume down buttons.
  5. saikiran4ever
    Jelly Bean Feb 8, 2021
    saikiran4ever , Feb 8, 2021 :
    It will go into recovery mode automatically if os can't be booted. I've faced this when i installed Open beta 2 on the latest stable version.
    I did a factory reset from recovery which solved the problem, but with data loss.
    You can go into recovery mode by pressing power button & volume down buttons at the same time for a few seconds.
  6. zab2x3z
    Cupcake Feb 8, 2021
    I am in recovery mode, but there is no way that i can find to flash a zip in the stock recovery
  7. zab2x3z
    Cupcake Feb 8, 2021
    the factory reset worked thank you so much
    saikiran4ever likes this.
