stuck on booting
  1. yuvrajsura
    Cupcake Aug 2, 2018
    yuvrajsura , Aug 2, 2018 :
    my one plus 3 is stuck on booting its not even opening or getting switch off what to do ??
  2. Liehjan
    Marshmallow Aug 2, 2018
  3. yuvrajsura
    Cupcake Aug 2, 2018
  4. upfreak
    Honeycomb Aug 2, 2018
    upfreak , Aug 2, 2018 :
    force restart by holding on the on switch for a couple of seconds.
  5. gautamgzb2
    Donut Aug 2, 2018
    xnutzii likes this.
  6. xnutzii
    Lollipop Aug 2, 2018
    xnutzii , Aug 2, 2018 :
    First of all, please search the forum...But sjnce I'm already here:
    Exactly as said above, just hold the Power button for a couple of seconds until the Display turns off. After it turned off, turn on again and the volume down button as well. After that enter your pin and install the ZIP via install from internal storage. If you can't find the file, it's maybe under the .OTA folder.
    If this doesn't work, then it's a bug, just flash the older ZIP file and you should be good to go.
  7. Pihraija
    Cupcake Aug 2, 2018
    Pihraija , Aug 2, 2018 :
    I have the same issue, but what worked for me was holding power+volume down and it booted. However my power button seems to be glitchy after the latest update, sometimes it registers two clicks when I only make one and the opposite... Anyone else?
