Stuck the phone whatever i do via OnePlus 8
  1. Yogamodle
    Donut Aug 12, 2021
    Yogamodle , via OnePlus 8 , Aug 12, 2021 :
    I cant do anything fast and whenever i operate the phone was hang for 10 or 15 sec and after few minutes system ui isn't responding .. REMOVED BY MOD
    I paid 42k..
    For hanging?
    Plz fix this issue asap ..
  2. pablofg1978
    Head Moderator Head Moderator Aug 12, 2021
    pablofg1978 , Aug 12, 2021 :
    Hello there,
    Please mind your language.
    This is a community forum, not support.
    Use the feedback section on the community app to submit your issues directly to oneplus.
    You can also contact support or visit a service center
    https://oneplus.com/support
    puccellino and Aaron2017 like this.
  3. Viraj Pnvs
    Gingerbread Aug 12, 2021
  4. Mustakim512634
    Eclair Aug 12, 2021
  5. puccellino
    Lollipop Aug 14, 2021
    puccellino , Aug 14, 2021 :
    This is an error that shows up often when a Google app is interfering with the system UI. It's probably caused by an update of an app you have.
    Make sure you are on the latest version of Oxygen. If the issue keeps reoccurring, look at the apps that have been recently updated around the time of the error messages, and uninstall updates.
    If it still persists I would uninstall all apps start of in safe mode and see if the issue is recurring. Then slowly reinstall each app at a time and see which app causes the problem.
    It's time consuming but effective.
