14
[Submitted] Stuttering/frame skip while scrolling [Oxygen 10 BUG on all 7T/7TPRO/7PRO]
Do you have this stuttering/frame skip while scrolling?
  1. Yes
    96.4%
  2. No
    3.6%
  1. Tex99
    Froyo Mar 8, 2020
    Tex99 , Mar 8, 2020 :
    HOW TO REPRODUCE:
    -90hz (more visible) or 60hz
    -Light theme (also with dark but it's easier too see on light)
    -Open settings and do little scroll with the finger (don't leave the finger on display)
    -Look at the written texts ("Battery" fro example): they don't do a fluid transition up or down, they don't flow on the screen, but they "appear-disappear", it seems that they jump some pixels. Infact there is multiple frame skip every time that you scroll.
    It happens every time you scroll on all apps
  2. Tex99
    Froyo Mar 8, 2020
    BUG:
    There is always a stuttering/frame skip while scrolling on every Oneplus 7T/7TPRO/7PRO with Android 10, on every app and every time you scroll.
    1)
    This is the complete video and here the stuttering is so visible, moreover you can see how to reproduce it (watch it on pc at full quality 1080p60 and full screen):
    2) If you watch this slowmotion video you can see how the written "Batteria" (when it appears stutter in red) does a sort of jump because of frame skip (I also added a frame count so you can be sure that the video is original):
    3) I did other test on my 7T with "Profile Rendering HWUI" and as you can see from the screenshots, If you do little scrolls there are serious frames drop (see the spikes):
    -Screenshots at the end of the post-
    HOW TO REPRODUCE:
    -Animation 0.5 or 1 (it's the same)
    TEST:
    Tests I did on both 60hz and 90hz and light theme (easier to see than dark mode):
    1- Oneplus 7T frosted silver OOS 10.0.6/10.0.7/10.0.8: stuttering is PRESENT
    2- Oneplus 7T frosted silver OOS 10.0.1: stuttering is PRESENT
    3- Oneplus 7T glacier blu OOS 10.0.1: stuttering is PRESENT
    4- Oneplus 7T glacier blu OOS 10.0.1: stuttering is PRESENT
    5- Oneplus 7T PRO OOS 10: stuttering is PRESENT
    6- Oneplus 7 PRO OOS 10.0.2: stuttering is PRESENT
    7/8- Oneplus 7 PRO OOS 9 and Oneplus 6T with OOS 9: stuttering is NOT PRESENT
    OTHER REPORTS AND TESTIMONIALS:
    1)
    https://forums.oneplus.com/threads/...g-on-all-7t-7tpro-7pro.1148402/#post-21228630
    2) https://forum.xda-developers.com/oneplus-7t/help/lag-scroll-7t-series-android-10-t4012171
    RESULTS:
    I'm pretty sure that this bug is due to Oxygen Os on Android 10 (on 7 Pro with Pie is not present) and it is present on all 7T/7TPRO/7PRO.
    Clear system cache, factory reset, block 90hz etc.. are all useless solutions (I tried).
    OnePlus still didn't fix the issue, in these condictions the 90hz are pretty useless.
    "Profile Rendering HWUI" screenshots:
  3. Fatumboy
    Gingerbread Mar 19, 2020
    Fatumboy , Mar 19, 2020 :
    I have an absolutely similar problem, nothing helps...
    Why aren't the developers responding to this problem in any way?!!!
    YnGWiE27 and Tex99 like this.
  4. renz2ho
    Froyo Mar 22, 2020
    renz2ho , Mar 22, 2020 :
    maybe they don't care because no one user reading while scrolling. If the user will read they will scroll slowly and stop and read the text.
    Tex99 likes this.
  5. abdo_01
    Cupcake Mar 22, 2020
    abdo_01 , Mar 22, 2020 :
    I have the same problem on my oneplus 7t. I wish Oneplus fix this problem soon
    Tex99 and Fatumboy like this.
  6. iamrohitparmar
    Gingerbread Mar 23, 2020
    iamrohitparmar , Mar 23, 2020 :
    I also have this same problem on 7t. In twitter it is worst 60 hz phone feels better at that time. OnePlus plz fix it.
    Abb4d0n and Tex99 like this.
  7. casiocas7677
    Cupcake Mar 23, 2020
  8. Acrexp
    Cupcake Mar 31, 2020
    Acrexp , via OnePlus 7T , Mar 31, 2020 :
    I have noticed this as well.
    I also have issues with say in and text or even a few minutes ago when I was trying to chat with Jeena in support. while texting it would freeze.
    In Chrome things in a tab would freeze. you could go to another tab and it would be fine. come back to the frozen tab and it would work.
    I kinda chalked this up to issues in the Beta 2 because I can't remember these things being an issue til. I installed it.
    DEVELOPERS IF YOU ARE REALLY LISTENING........
    PLEASE PLEASE.
    Put in the next update a way to togle on and off the screenshot when both the power button and volume down buttons are pushed simultaneously.
    michaelliao07 likes this.
  9. BENJZ89
    Honeycomb Apr 1, 2020
    BENJZ89 , Apr 1, 2020 :
    Stuttering , in game glitches bug suddenly stopping
    Sound is not good as well as before , dolbyatmos must be headset in ear , speaker isnt clean .
    OB3 notice will develop this bug .
    everything slower than before .
    but , i like this feature about double tap to wake-up screen and ambient display in merging together . thats so far i wanna tell .
    gracias.
  10. abdo_01
    Cupcake Apr 4, 2020
  11. Tex99
    Froyo Apr 4, 2020
    Tex99 , Apr 4, 2020 :
    of course nope, oneplus will never fix it, I'm sure
  12. tianissimo
    Cupcake Apr 6, 2020
    tianissimo , Apr 6, 2020 :
    I've just bought my new 7T Pro and found the issue with touch scrolling. It's mostly noticeable while playing pubg mobile. I've tested it with just App Drawer and could see the problem. Slightly touch to scroll up and down with the same motion and touch distance, scrolling will sometimes go too far or too slow.
    At first, I thought it's caused by the pre-installed screen protector, but after removing it didn't help. Then I found this thread so it's not only me noticing this problem then. This issue is a real blocker for pro player to play FPS games using Oneplus.
    @Tex99 I followed from your old threads for this issue. I'll help upvote it.
    Abb4d0n, Fatumboy and Tex99 like this.
  13. Pandatek
    Froyo Apr 10, 2020
    Pandatek , via OnePlus 6T , Apr 10, 2020 :
    facing exact same issues/problems. is disgusting and unbelievable OnePlus is doing absolutely nothing to try to solve this ongoing issue after Android 10.
  14. Fatumboy
    Gingerbread Apr 11, 2020
    YnGWiE27, E1586784195217 and Tex99 like this.
  15. ATMSRINIVASAN
    Eclair Apr 11, 2020
    ATMSRINIVASAN , via OnePlus 7 Pro , Apr 11, 2020 :
    Hello everyone sinces the OnePlus is big brand in smartphone world were the question rises about emojis like apple or samsung ar emjois or Google Play grounds every brand has there own why not in OnePlus devies sinces it's has all the capables
    live captions were OnePlus 7t nd 7t pro received a live captions options olnot on OnePlus 7 and 7pro hope should be released soon with AOD
    Sorecazm likes this.
  16. E1586784195217
    Cupcake Apr 13, 2020
    E1586784195217 , Apr 13, 2020 :
    Hello everyone. My phone also has scrolling issues. This happens in all applications. I have 7t 10.0.9
  17. abdo_01
    Cupcake Apr 14, 2020
    abdo_01 , Apr 14, 2020 :
    Factory reset will solve the problem or not ?
  18. Tex99
    Froyo Apr 14, 2020
    Tex99 , Apr 14, 2020 :
    absolutely nope, it's a software issue that only oneplus can fix
  19. DeeJaaWoo
    Honeycomb Apr 17, 2020
    DeeJaaWoo , Apr 17, 2020 :
    Interesting but sad that oneplus never looks at the suggestions anymore ... its not a community driven forum like it was before ....
    On the issue ....
    well i saw the videos ... yes there seems to be frame skip ... but what if its not just the frame skip .. but an issue with the acceleration of scroll...
    the way you are scrolling to produce the stutter ... it could be the initial acceleration and deceleration of scroll....
    i do a lot of Instagram ... and i never see frame skips...
    just like you see a smooth stop when it starts to decelerate ... the code is not understanding the sudden acceleration+stop ... thus this might be causing the frame skip .... not a bug ...
    Those were just my thoughts ... only someone from Op can answer it better ...
    i have a OP7Pro in India ...
  20. Fatumboy
    Gingerbread Apr 17, 2020
    Sorecazm and E1586784195217 like this.
