11
[Submitted] Stuttering/frame skip while scrolling [Oxygen 10 BUG on all 7T]
  1. Tex99
    Froyo Feb 21, 2020
    Tex99 , Feb 21, 2020 :
    I think it's better from PC, you have to go to feedback section, create a new thread and report the bug
    there isn't solution at the moment, only oneplus can fix it. some users have resolved with custom roms and it seems they don't have this issue
  2. Tex99
    Froyo Feb 25, 2020
    Tex99 , Feb 25, 2020 :
    of course the issue is still present on 10.0.8, that's a shame oneplus
    Abb4d0n likes this.
  3. Tex99
    Froyo Mar 8, 2020
  4. #24
    Abb4d0n and Tex99 like this.
  5. Tex99
    Froyo Mar 16, 2020
    Tex99 , Mar 16, 2020 :
    hi, well good news man, I'm on 7t but I'm not in the beta program so I have to wait until next stable to see if it fixed :(
  6. Fatumboy
    Froyo Mar 19, 2020
    Fatumboy , Mar 19, 2020 :
    I have an absolutely similar problem, nothing helps...
    Why aren't the developers responding to this problem in any way?!!!
    OnePlus 7 pro
    Tex99 likes this.
  7. Fatumboy
    Froyo Mar 19, 2020
    5urv1v0r
    Hi. On the new open beta the stuttering problem seems to be gone in my OP 7T Pro. I can clearly see that the scrolling is very fluid now.
    Can you confirm on your side?​
    I've set beta 10, the problem remains...
    OnePlus 7 pro
    Tex99 likes this.
  8. Tex99
    Froyo Mar 21, 2020
    Tex99 , Mar 21, 2020 :
    I installed open beta on 7T, stutters while scrolling are still present.
    As soon as I can I will sold this device, it seems that oneplus is not able to take care of their devices, probably last time with them.
    Pandatek and Fatumboy like this.
  9. Pandatek
    Eclair Apr 10, 2020
    Tex99 likes this.
  10. Pandatek
    Eclair Apr 10, 2020
  11. Fatumboy
    Froyo Apr 11, 2020
    Tex99 likes this.
  12. E1586784195217
    Cupcake Apr 13, 2020
    E1586784195217 , Apr 13, 2020 :
    Hello everyone. My phone also has scrolling issues. This happens in all applications. I have 7t 10.0.9
  13. Tex99
    Froyo Apr 27, 2020
    Fatumboy likes this.
  14. 5urv1v0r , via OnePlus 7T Pro McLaren Edition , May 2, 2020 :
    Tex99 (and others) are you using gesture navigation? do you see any improvements in scrolling if you use button navigation?
    the reason for my question is that i was playing a game that requires lots of swiping from the sides of the phone. i got bothered with these swipes being read as a back gesture and kicking me out of the game so i turned the gesture navigation off and used the button navigation. after finished playing the game i kept the button navigation and noticed a tremendous improvement in the scrolling stuttering. every scrolling seems now buttery smooth. i have been playing for quite some time so i am afraid that my judgement can be compromised. are all those witnessing the stutters using gesture navigation? if you are, can you please switch to button navigation and check if the stutters are gone. i will keep using the button navigation and see if the scrolling remains as smooth as it is now and report back.
    note: with the open beta i noticed a good improvement in scrolling but sometimes the stutters show up especialy in Google photos.
    Tex99 likes this.
  15. Tex99
    Froyo May 2, 2020
    Tex99 , May 2, 2020 :
    Hi man, thank you for reporting your experience as always :)
    I tried to use only the nav bar but unfortunately I didn't notice any type of improvement. I still see frame drop/stuttering while scrolling. I'm really curious to try 8 series in a shop to see if also they have this issue.
    I'm also on open beta on 7T but I didn't see any improvements on scrolling.
    The last hope at this point is android 11, oneplus is not able to fix this.
