substratum theme
  1. G_Mohammad_Al-Shuwaiee_r
    Donut Oct 22, 2017
  2. Impulse_CK
    Honeycomb Oct 22, 2017
    Impulse_CK , Oct 22, 2017 :
    I think you using substratum in non rooted device. if you use substratum in rooted device you will not face such a issue.
  3. vintagetech
    Honeycomb Oct 23, 2017
    vintagetech , Oct 23, 2017 :
    Is your phone rooted? If it is not rooted, then substratum needs the XDA Andromeda app from the Google Play store to work. The Andromeda app requires the unrooted phone to reconnect to the computer to activate substratum's elevated permissions after every reboot. This is due to the security measures in Android protecting you from malicious apps or misbehaving apps. You will still have the theme you last used after reboot. You only need to activate substratum via Andromeda if you intend to make any changes to your theme.
    You will need to root your phone inorder to use substratum without connecting your phone to a computer after every reboot.
  4. G_Siva_Kumar_JFVs
    Eclair Oct 23, 2017
