2
substratum with Andromeda on stock oreo rom
  1. shabiranwar08
    Froyo Dec 28, 2017
    shabiranwar08 , Dec 28, 2017 :
    thanks guys. will try it right away. not sure why i didnt receive any notification when people reply here
  2. Solanum
    Honeycomb Dec 28, 2017
    Solanum , Dec 28, 2017 :
    The best is PitchBlack, i tried all and is the best with difference
  3. Solanum
    0 issues
    swvinod likes this.
  4. shabiranwar08
    Froyo Dec 28, 2017
  5. shabiranwar08
    Froyo Dec 28, 2017
    i prefer swift dark :)
    Lord_Mithalvaiel likes this.
  6. Solanum
    It's very outdated with apps, PitchBlack is up to date with all apps
    jayianoneplus and shabiranwar08 like this.
  7. shabiranwar08
    Froyo Dec 28, 2017
    oh ok ll check it out
  8. Lord_Mithalvaiel
    Donut Dec 29, 2017
    Lord_Mithalvaiel , Dec 29, 2017 :
    I have been having so many problems with it on my unrooted OnePlus 5 on all the open betas and the stable oos 5.0.0. Please help. I've tried several themes.
    jayianoneplus likes this.
  9. jayianoneplus
    Gingerbread Dec 30, 2017
    jayianoneplus , Dec 30, 2017 :
    sir, im really interested to try this on my op5 oreo. can you please give more details on your experience? especially the theme you are using?
    if i will try it, i need the near perfect theme that will not cause problems with the system. i read something that it could easily cause bootloops after system updates or even small app updates.
    please...
  10. Hydra Bob
    Marshmallow Dec 30, 2017
    Hydra Bob , Dec 30, 2017 :
    If you have TWRP recovery you can fix that without doing a factory reset.
  11. Lord_Mithalvaiel
    Donut Dec 30, 2017
    Lord_Mithalvaiel , Dec 30, 2017 :
    same. I tried and failed at this too
  12. jayianoneplus
    can you please share a little more? i do not want to end up with factory reset.
  13. jayianoneplus
  14. jayianoneplus
    this is what i need. thanks for sharing this sir![e]1f44d[/e]
  15. Lord_Mithalvaiel
    Donut Dec 30, 2017
  16. jayianoneplus
    sir, i am just curious. what is that AMOLED thing on your screenshot? is that a 3rd party app? why do you need that? isn't amoled enabled by default in op?
  17. F_Abhijit_Shrikhande_sbx
  18. Someshwar_Guru
    Honeycomb Dec 30, 2017
    Someshwar_Guru , Dec 30, 2017 :
    The only issue I faced was the application couldn't apply the ozone theme I downloaded.I ended up downloading a legacy version of ozone which seemed to solve the problem.Cheers
    #38
  19. Solanum
    Solanum , Dec 30, 2017 :
    theme: PitchBlack, updated 2 times per week.
    No issues and the phone looks great. 2 weeks testing and no fc or random reboots, everything works perfect.
    #39
  20. G_Vasu_Manepalli_GIDm
    Eclair Dec 30, 2017
    #40
