2
substratum with Andromeda on stock oreo rom
  1. Quantaurix
    Donut Dec 30, 2017
    #41
  2. F_Abhijit_Shrikhande_sbx
    Gingerbread Dec 30, 2017
  3. F_Abhijit_Shrikhande_sbx
  4. F_Abhijit_Shrikhande_sbx
    #44
  5. jayianoneplus
    Gingerbread Dec 31, 2017
    jayianoneplus , Dec 31, 2017 :
    i believe you are rooted? i am using andromeda for substratum and I've been experiencing errors sometimes. it took me awhile to test overlays and combine it with other module. i am using pitchblack as main module and ozone for addt'l features i want.
    #45
  6. jayianoneplus
    for free, you can start with Ozone.if you want more customization, you can buy PitchBlack module. i am using both.
    #46
  7. jayianoneplus
    i experienced few errors but nothing too serious. based on what i read,the apps are improved now not to cause mess with Android system.
    #47
    F_Quentin_Hayes_Mqtu likes this.
  8. jayianoneplus
    you can simply disable/uninstall overlays then reboot to return to original settings.
    #48
  9. F_Quentin_Hayes_Mqtu
    Froyo Dec 31, 2017
    #49
    jayianoneplus likes this.
  10. F_Quentin_Hayes_Mqtu
    Froyo Dec 31, 2017
    #50
  11. Navinmholkar
    Navinmholkar , Dec 31, 2017 :
    what if goes in to bootloop?
    #51
  12. F_Quentin_Hayes_Mqtu
    Froyo Dec 31, 2017
    F_Quentin_Hayes_Mqtu , Dec 31, 2017 :
    pixel navbar overlay and black ui theme work fine. the black theme colour is throughout the settings, on the notification tiles, the app drawer scroller.
    #52
  13. jayianoneplus
    i am already using it sir. you need andromeda paid app in partner with substratum app to make it work. you will be needing pc/laptop to run desktop suite for andromeda. it is not that convenient.
    #53
  14. jayianoneplus
    if you are on stock rom OP5 official Oreo, nonroot, i think there will be no bootloops like me. if you find it hard to follow instructions of substratum app and Andromeda app, it would be better to stay on stock.
    #54
    Navinmholkar likes this.
  15. ponlong22
    #55
  16. jayianoneplus
    the ozone module i am using is from google play. i think it is the updated one. works fine for my op5.
    #56
  17. jayianoneplus
    you can search for the complete tutorial in xda sir. they are the ones who host for it. its simple really. you just need patience and time to explore it.
    #57
  18. Someshwar_Guru
    Honeycomb Dec 31, 2017
    Someshwar_Guru , Dec 31, 2017 :
    The updated one doesn't seem to work on my OnePlus 3..had to download an old one from apkmirror.
    #58
  19. Solanum
    Solanum , Dec 31, 2017 :
    No root, locked bootloader. 0 issues xD
    #59
    Someshwar_Guru and jayianoneplus like this.
  20. Navinmholkar
    I didn't find it hard to follow instructions but I don't want to do factory reset. thanks by the way I will try it tonight.
    #60
