Substratum
  1. xBioFur
    Honeycomb Apr 29, 2018
    xBioFur , Apr 29, 2018 :
    So substratum ozone is not working anymore on 8.1.1. Is that true or am I doing something wrong?
    AshishPrinz likes this.
  2. idkwhoiam322
    Nougat Apr 29, 2018
    idkwhoiam322 , Apr 29, 2018 :
    Works just fine.
    Build and enable themes>Reboot(Required post March Security Patch, thank Google)>Manager tab under Substratum>Select all overlays you want to enable(or simply hit the switch to select all)>Change Overlay States(or enable).
    Nick 59 and xBioFur like this.
  3. xBioFur
    That is my problem. The themes are not showing up in the place where you can enable them. Neither after rebooting.
  4. MentalDraco
    Marshmallow Apr 29, 2018
    MentalDraco , Apr 29, 2018 :
    Works fine for me. Try to build and enable them and enable them one at a time from the build screen from Ozone
    xBioFur likes this.
  5. idkwhoiam322
    Nougat Apr 29, 2018
    Works fine for me, perhaps uninstall everything and try grabbing latest substratum and theme again?
    xBioFur and Nick 59 like this.
  6. xBioFur
    Honeycomb Apr 30, 2018
    xBioFur , Apr 30, 2018 :
    Help it still does not work i uninstalled all the themes and installed them again. I can see them in the app list but they dont show up in substratum
  7. MentalDraco
    Marshmallow Apr 30, 2018
    MentalDraco , Apr 30, 2018 :
    You running it with Andromeda ?
  8. xBioFur
  9. xBioFur
  10. DerDavid
    Eclair May 19, 2018
  11. xBioFur
    Honeycomb May 19, 2018
    xBioFur , May 19, 2018 :
    So i rooted my OP5 but it still asks for andromeda. Why. what do i have to do.
  12. xBioFur
  13. MentalDraco
    Marshmallow May 19, 2018
    MentalDraco , May 19, 2018 :
    not sure why I have a un-rooted phone and I got andromeda and works fine, not sure about the rooted route.
  14. xBioFur
    i had andromeda too. Then i decided to root.
  15. idkwhoiam322
    Nougat May 19, 2018
    idkwhoiam322 , May 19, 2018 :
    Give substratum root priveleges.
    Artemus likes this.
  16. AshishPrinz
  17. xBioFur
  18. DerDavid
    Eclair May 19, 2018
  19. João Carlos Chande
    Gingerbread May 19, 2018
    João Carlos Chande , May 19, 2018 :
    Substratum is working fine for me.
    I'm using pitch black theme and is working amazingly.. Get pitch black from Google store..
  20. mfarooqueone
