28
Sudden Flood of Notifications?
  1. vijaychinna4017
    Cupcake Oct 7, 2018
  2. Shubham_Verma30
    Donut Oct 7, 2018
  3. Hydra Bob
    Marshmallow Oct 7, 2018
    Hydra Bob , Oct 7, 2018 :
    Bruh you're spending more time arguing why your problem is self-evident than if you just took the time to explain the issue properly. And plenty of people who manage to root and install custom ROMs can still somehow make the most noobish mistakes and oversights. You shouldn't take anything for granted.
    yourdesiredusername likes this.
  4. Waveform Modifier
    Waveform Modifier , Oct 7, 2018 :
    No. That is not true. There are plenty of idiots out there that does stupid things to their phones but blame OnePlus or the phone for it. So no, the community can't rule anything out.
    Also, what do you got to gain by asking "Have you noticed over the past couple of days?". That in itself serve no purpose.
  5. AkBar3339
    Donut Oct 7, 2018
    AkBar3339 , Oct 7, 2018 :
    I have the same issue, latest official ROM, no root. It is weird because there was no update before it changed.
  6. abhi_987
    Cupcake Oct 7, 2018
  7. upasana_m
    Gingerbread Oct 7, 2018
    upasana_m , Oct 7, 2018 :
    Same issue on my OnePlus 5. No idea why this is happening. I had to force stop the apps manually.
    Btw, did you notice two "cartoons" who kind of comments on every post to show how much they "know about the community" but has actually never been able to understand a users problem and provide a solution? :p
  8. Chitrayan_Ray
    Cupcake Oct 7, 2018
    Chitrayan_Ray , Oct 7, 2018 :
    Yeah..i am also having this issue from the past few days...it has something to do with the latest beta build's battery optimization
  9. the_reckoner
    Ice Cream Sandwich Oct 7, 2018
    nitin.nmg likes this.
  10. Darshil_Raichura
    Honeycomb Oct 7, 2018
  11. upasana_m
    fyi, i am on 5.1.4 build
  12. puma95
    Jelly Bean Moderator Oct 7, 2018
    debjit1990 likes this.
  13. umashankar.jsr
    Froyo Oct 7, 2018
    umashankar.jsr , Oct 7, 2018 :
    Yes, same with me. Suddenly I started getting push notifications which I never received before. Due to this battery started draining very fast.
  14. F_Ravi_Teja_IBcL
    Cupcake Oct 7, 2018
    F_Ravi_Teja_IBcL , Oct 7, 2018 :
    yes I'm also facing Same problem
  15. Debtanu Biswas
    Eclair Oct 7, 2018
    Debtanu Biswas , Oct 7, 2018 :
    Same here, i think battery optimization stopped working? So that's why all apps now running in background but also battery usage showing no changes. Strange 1538903717594.jpg
    AkBar3339 likes this.
  16. ishaanbahal
    Eclair Oct 7, 2018
    ishaanbahal , Oct 7, 2018 :
    Apps don't need to run in the background to show notifs, on callback from fcm, the app worker is started to handle the notification, and it shuts down. Hardly takes many cpu cycles to do that, and that's why it isn't considered to be shown in the battery usage list since the used mAh would be really low, quite lower than 1% minimum.
  17. Debtanu Biswas
    Eclair Oct 7, 2018
    Ok thanks for the info, but what causing this, any idea?
  18. Horsault
    Marshmallow Moderator Oct 7, 2018
    Horsault , Oct 7, 2018 :
    You posted under OP5/5T.
    You can check.
    Those are 2 distinct devices.
    Considering the way you're answering, this will be my last attempt to help you.
    #38
  19. ishaanbahal
    Eclair Oct 7, 2018
    It seems like a remote flag was moved. My friends on op3t and op6 are also facing this issue, so it isn't just limited to op5/5t. I'm not related to OnePlus so can't quite tell what they did, but I can say for sure, I loved my previously quiet phone, not so much anymore. [e]1f623[/e]
    #39
    Debtanu Biswas and debjit1990 like this.
  20. Pratik Deogade
    Cupcake Oct 7, 2018
    #40
