28
Sudden Flood of Notifications?
  1. vipinnair22 Froyo Oct 8, 2018
    vipinnair22, Oct 8, 2018 :
    That's the million dollar question!
    #61
    Abhi Dahiya and AkBar3339 like this.
  2. TSKK97 Cupcake Oct 8, 2018
    TSKK97, Oct 8, 2018 :
    Yeah bro, I have a OP6, and same as you this weekend I got countless notifications from apps which I don't use frequently as you mentioned. I didn't understand at all......I don't get notifications at all from these apps but all of a sudden they started popping up. Annoying....
    #62
  3. Mr_Cyrox KitKat Oct 8, 2018
    Mr_Cyrox, Oct 8, 2018 :
    Actually come to think of it...
    Reddit started pumping notifications to me a few days back...
    I think it's a thing on beta too...
    #63
  4. H1514904288791 Eclair Oct 8, 2018
    H1514904288791, Oct 8, 2018 :
    Yup, it's a problem when automation fails.
    #64
  5. F_Mousam_Saha_WDWV Cupcake Oct 8, 2018
    #65
  6. mdevnath014 Cupcake Oct 8, 2018
    mdevnath014, Oct 8, 2018 :
    I have all noticed a similar trend but only after i enabled the deep clear of recent apps.
    #66
  7. guptatarun001 Cupcake Oct 8, 2018
    guptatarun001, Oct 8, 2018 :
    I am also facing the same problem from last few days. Let me try to explain the problem here:
    Let's say I have 50 apps installed on my phone. Now, earlier I was getting notification from my 10 most used apps which is fine. If I was opening an app(not so commonly used) then I was getting its notification only when opened. Now what is happening: I am getting all 50 apps' notification. As a result of which my notification drawer has become freaking lengthy & it is very difficult to look out for a particular app, let's say I did a banking transaction & I am looking out for OTP message in that list of notifications. believe me, it is a mess.
    #67
    Abhi Dahiya likes this.
  8. guptatarun001 Cupcake Oct 8, 2018
    #68
  9. Mr_Cyrox KitKat Oct 8, 2018
    #69
  10. H1514904288791 Eclair Oct 8, 2018
    #70
  11. venkateshbabuas Eclair Oct 8, 2018
    venkateshbabuas, Oct 8, 2018 :
    I also am facing same issue, all the apps for which I usually don't receive any notifications started sending them..
    I tried below method and it seems to have fixed the issue for now..
    goto battery settings - battery optimisation - click on 3 dot menu - Advances optimisation - disable "Advanced Optimisation"
    now reboot in to recovery and clear the cache
    after reboot enable the "advanced optimisation"
    this seems to have fixed the issue for now..
    #71
  12. Mr_Cyrox KitKat Oct 8, 2018
    #72
  13. H1514904288791 Eclair Oct 8, 2018
    #73
  14. vivekgokulraj Honeycomb Oct 8, 2018
    vivekgokulraj, Oct 8, 2018 :
    this seems to be suspicious. even I am receiving notifications from apps that I don't use frequently. Earlier no such issues happened. the problem to arise suddenly without any system updates from OnePlus?? how is that possible
    #74
    Gusco32 likes this.
  15. vipinnair22 Froyo Oct 8, 2018
    I've sent the logs and screenshots to a OnePlus bug hunter. He in turn has sent those logs to the dev team. Hope they're able to debug and rectify the issue asap.
    #75
  16. H1514904288791 Eclair Oct 9, 2018
    #76
    Gusco32 likes this.
  17. G_Ashesh_Chandrakar_saYg Cupcake Oct 9, 2018
    #77
  18. Supz Donut Oct 9, 2018
    #78
  19. Nick989893 Cupcake Oct 9, 2018
    Nick989893, Oct 9, 2018 :
    I have no idea what caused it, but I certainly know how to stop it, thanks to oxygen OS. Go to settings > Apps > Application list. Click on the annoying app in the list. The first option is notification. Click on it, you can turn it off completely or change its priority, decide if it should pop on the locked screen and a few more thing. "PROBLEM SOLVED".
    #79
  20. H1514904288791 Eclair Oct 9, 2018
    H1514904288791, Oct 9, 2018 :
    Sir... This is not a solution
    #80
    vipinnair22 likes this.
