Sudden Lag ..!!! via OnePlus 6T
  1. im_svj23
    Donut Apr 8, 2021
    im_svj23 , via OnePlus 6T , Apr 8, 2021 :
    Hi Team OnePlus,
    I am a OnePlus 6T user and my device suddenly get a lag which is very inappropriate. My device is only 64gb full and RAM is also more than sufficient. Google Chrome doesn't respond sometimes and the camera in the Instagram app doesn't open.
    I am looking forward for an update to see through this bugs and fix them. Hoping for Android 11 update too 😉.
    Thank you
    Team OnePlus ❤️
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 8, 2021
    Caomhin , via OnePlus 6T , Apr 8, 2021 :
    For Instagram, make sure you are using a Stable version. Beta versions may have issues at times. If you have a Beta version. Uninstalling Beta and install Stable may help your issues.
    For chrome, try the following.
    Clear Chrome App info Cache.
    Also open Chrome, go to Settings>Site Settings>Data Storedclick on Clear Data Stored.
    Also clear browsing history in Chrome Settings>Privacy>Clear Browsing Data. Select All Time for the Time Range, then Clear Data.
    See if that helps.
    And for lag, make sure you have the latest version of the OnePlus Launcher from the Playstore.
    Then clear the OnePlus Launcher App info Cache and restart the phone.
    Check if any or all of the above can help.
    im_svj23 and Bobbie63 like this.
  3. im_svj23
    Donut Apr 11, 2021 at 6:23 AM
    im_svj23 , via OnePlus 6T , Apr 11, 2021 at 6:23 AM :
    Thank you 😊
    Caomhin likes this.
  4. im_svj23
    Any News about Android 11 update.
  5. Deezl
    Cupcake Apr 11, 2021 at 7:27 AM
  6. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 11, 2021 at 8:43 AM
