suddenly my dash charging is not showing dash charging symbol
  1. F_Sharath_Gutha_nzid
    Eclair Sep 7, 2017
    F_Sharath_Gutha_nzid , Sep 7, 2017 :
    guys is this a bug or problem with my dash charger/mobile? please tell me if anybody has this problem. since from 3 days it is not showing dash symbol and battery charges very slow.
  2. rajeev5252
    Gingerbread Sep 7, 2017
    rajeev5252 , Sep 7, 2017 :
    check your wall socket..it is not getting enough voltage..if u r using a surge protector..please directly plug in to wall socket
  3. F_Sharath_Gutha_nzid
    Eclair Sep 7, 2017
    i'm using wall socket and i have checked every place in my three houses at different states ap & Telangana. it is not at all showing dash symbol everywhere. [e]1f622[/e]
  4. Sushrut_Shendre
    Cupcake Sep 7, 2017
  5. rajeev5252
    try to disconnect and reconnect the cable with the adaptor...if it still fail then i think you need to contact service centre...also try clear cache from recovery as well...it might help.
  6. Sushrut_Shendre
    Cupcake Sep 7, 2017
    Sushrut_Shendre , Sep 7, 2017 :
    Are you using any cover for phone then remove it turn off your phone for while then without cover charged your phone & see
  7. G_plusone
    Nougat Sep 7, 2017
    G_plusone , Sep 7, 2017 :
    If you are using dash charger and dash cable Check whether the power adapter is inserted properly into the socket.
    Check if the USB cable's both ends are properly inserted.
    Check if there is too much dirt in the USB cable
  8. F_Sharath_Gutha_nzid
    Eclair Sep 7, 2017
  9. F_Sharath_Gutha_nzid
    Eclair Sep 7, 2017
    i have tried to disconnect cable and reinserted with adapter.
  10. F_Sharath_Gutha_nzid
    Eclair Sep 7, 2017
    no cover no screen guard
  11. F_Sharath_Gutha_nzid
    Eclair Sep 7, 2017
  12. rajeev5252
    i would suggest try clear cache first...if still not resolved then dont wait for next update..contact service center as soon as possible.
    H1512062085641 likes this.
  13. mk92
    mk92 , Sep 7, 2017 :
    try with someone else's charger, see if it works or not.
    try switching off your phone & then charge please.
    if it worked that means your charger is damaged,
    if still doesn't work then there is some software glitch.
    but ensure before trying that your phone is not hot. its completely cool
  14. Keshiji
    Keshiji , Sep 7, 2017 :
    Take a photo of the cable (specially close to the connectors) and a photo of the Dash adapter. Also a photo of the USB-C port might be a good idea.
    I seriously think this could be happening because you tugged the cable or something.
    GL!
  15. G_venkat_r_fFci
    Honeycomb Sep 7, 2017
    G_venkat_r_fFci , Sep 7, 2017 :
    I am giving you the correction solution.
    once remove the USB from the charger and fix it tightly again
    your problem will solve
  16. mayushjain
  17. mayushjain
    mayushjain , Sep 7, 2017 :
    try someone else's proprietary cable because other cables won't work still there's issue try using charger too if you still run out of luck maybe your phone has a problem
  18. Blazingsun81
    Cupcake Jun 10, 2018
    Blazingsun81 , Jun 10, 2018 :
    I have the same problem with my phone ,I contacted the repair centre , they quoted me $300+labour &shipping to fix the charge port &board .
    I only had my one plus 5 for 8 months
  19. Blazingsun81
    Cupcake Jun 11, 2018
    Blazingsun81 , Jun 11, 2018 :
    So solved my charging issue,
    By taking a pin and carefully removing a bunch of dirt in the charge port.
    Works good as new
