[SUGGEST] Best Kernel for stock CM12.1
  1. swieke
    Honeycomb Apr 21, 2015
    swieke , Apr 21, 2015 :
    Alright guys, I just flashed my CM12.1 and I want to know most recommended custom kernel for this ROM. :)
  2. VenomSnake8
    Gingerbread Apr 21, 2015
    Nyan_ likes this.
  3. swieke
    How can you recommend it?
  4. VenomSnake8
    VenomSnake8 , Apr 21, 2015 :
    Good battery life and performance. I get about 6 hours of screen on time.
    kaushal7007 likes this.
  5. swieke
    Is it laggy or other problems?
  6. kaushal7007
    Donut Apr 21, 2015
    kaushal7007 , Apr 21, 2015 :
    what about cm12 or cm12s i use this ota manul downloaded and installed since 4days... so i need custom kernel which gives me battery with performance
  7. VenomSnake8
    I don't have any problems. My phone did get a little slower, but it's not very noticeable.
  8. VenomSnake8
    You can try Boeffla kernel.
    veratoloz2005 likes this.
  9. Le Beard Guy
    Le Beard Guy , Apr 21, 2015 :
    It's often seen as impolite to hijack other people's threads.
  10. swieke
    Honeycomb Apr 22, 2015
    swieke , Apr 22, 2015 :
    What makes Boeffla kernel good?
  11. h7deaux
    h7deaux , Apr 22, 2015 :
    I've heard good things about AK, but I'm curious to see what all the options are first. Bump
  12. DaxNagtegaal
    Marshmallow Apr 22, 2015
    DaxNagtegaal , Apr 22, 2015 :
    Trial and error my friend, flash it and find out
    becauseimmanual likes this.
  13. hendrab
    Froyo May 6, 2015
    hendrab , May 6, 2015 :
    Hi vn84. Can you help me collaborate on how you archieve 6hours? I am on stock ROM cm12.1 just installed ak kernel. Used trickster mod change the governor to zzmove anything else? Or can you recommend tools apps or guide that I should take to get this. Currently my on screen time is at 3-4 hours I mainly use my phone for movies
  14. jmolinabermejo
    Honeycomb May 6, 2015
  15. hendrab
    Froyo May 6, 2015
    jmolinabermejo likes this.
  16. Rushvanth
    Gingerbread May 6, 2015
  17. swieke
    swieke , May 6, 2015 :
    it has been released lately i think?
  18. swieke
    correct me if i'm wrong
  19. hendrab
    Froyo May 6, 2015
    They release the r42 which only support cm12 not the cm12.1. R43 is coming soon to support cm12.1. So if you're running on cm12 then you're lucky.
