270
[Survey] How should we revamp Alert Slider?
  1. Nezumi_ KitKat Sep 28, 2017
  2. GeertBerkers Lollipop Sep 28, 2017
    GeertBerkers, Sep 28, 2017 :
    Yeah! But they would make my app useless :mad:
    Anyway, if OnePlus did a good job immediately, I didn't have to devlop an app for it...
    superplus likes this.
  3. Boredatwork Donut Sep 28, 2017
    Boredatwork, Sep 28, 2017 :
    I think with the gaming DND implementation, should be game DND, silent with vibrate option, and normal
    and please switch it upside down (top being normal) makes lot more sense
  4. andrew badinski Froyo Sep 28, 2017
  5. snabb Honeycomb Sep 28, 2017
  6. kunalsapru Cupcake Sep 28, 2017
    kunalsapru, Sep 28, 2017 :
    I just want to swap 'Ring' and ' Vibrate'. I don't use Do not disturb, so its of no use to me. Slide up: Ringer and Slide down: Vibrate.
  7. Retr_0 Ice Cream Sandwich Sep 28, 2017
    Retr_0, Sep 28, 2017 :
    Neither, just let us remap it as we wish, and also not use it if we don't,like third party rooms, the slider is for when not using the phone, while using it, we can use the volume buttons or the software sliders
  8. Riaanschutte04 Cupcake Sep 28, 2017
    Riaanschutte04, Sep 28, 2017 :
    Ring>Vibrate>Silent :D
    Fursan Afzal likes this.
  9. elanglois Lollipop Sep 28, 2017
    elanglois, Sep 28, 2017 :
    Screenshot_20170928-051248.png I think that the only valid option is to allow each user to decide for themselves. Many custom ROMs allow each position to be customized, allowing vibration, DND, total silence, or whatever to be assigned as you see fit to each position. Then, also allow scheduled DND.
    Mr. Vandelay likes this.
  10. G_MUNEER_HUSSAIN_ZFAq Cupcake Sep 28, 2017
    G_MUNEER_HUSSAIN_ZFAq, Sep 28, 2017 :
    Currently, notification alerts sounds is managed via physical alert slider located in the left side of the handset. We don't have any option to change the alert notification sounds virtually on the screen. So, if you add the feature / setting in status bar, (single tap - Sound, Double tap - Vibrate & triple tap - Mute/DND) it will be convenient and fast. It also helps in preserving
    physical alert slider button which might gets damaged in the future if used frequently & cant change notification.
    Need alert change option in status bar
    Frequent use of physical alert slider may damage it
  11. jbc98b Ice Cream Sandwich Sep 28, 2017
  12. schlomm.darmann Gingerbread Sep 28, 2017
  13. ECKoBASE Froyo Sep 28, 2017
    ECKoBASE, Sep 28, 2017 :
    keep it the way it is, three options are better than two.... remember these options are customisable.....make it what you want it to be
  14. B.yashaswi Ice Cream Sandwich Sep 28, 2017
  15. Kenahuja Gingerbread Sep 28, 2017
    Kenahuja, Sep 28, 2017 :
    The current default of Ring/DND/Silent works perfectly for me personally and I wouldn't want it to be changed. However it is still not a perfect implementation overall as the volume rockers do not let you reduce ring volume down to just vibrate.
    IMHO, the perfect combination would be as follows :
    Alert Slider : Ring/DND/Silent
    Volume Rockers : Adjust Ring Volume from Vibrate only to Full Volume Ring.
  16. camohan Marshmallow Moderator Sep 28, 2017
    camohan, Sep 28, 2017 :
    Thread merged.
  17. gpolydoros Gingerbread Sep 28, 2017
    gpolydoros, Sep 28, 2017 :
    Please bring back scheduled DnD. On all supported OnePlus phones, not just on your next flagship.
  18. Emanuel@ Donut Sep 28, 2017
    Emanuel@, Sep 28, 2017 :
    The three-way hardware button is fully set up with the features: Ring / Vibration / Silent / Do not disturb / - and others by setting up the software.
  19. G_Faheem_Yazdani_(Feemy8 Gingerbread Sep 28, 2017
  20. patrice58 Ice Cream Sandwich Sep 28, 2017
    patrice58, Sep 28, 2017 :
    Yes it does increase the volume when on silent mode. At least it does on the OP3.
