258
[Survey] How should we revamp Alert Slider?
  1. Selina_Mai Cupcake Dec 29, 2017
    shreeshmanasvi likes this.
  2. newnews Eclair Dec 31, 2017
    nickhell and stephanejap like this.
  3. vaggelas Cupcake Dec 31, 2017
  4. Aniruddha Deshpande Froyo Jan 1, 2018
    Aniruddha Deshpande, Jan 1, 2018 :
    you can give display mode options with it... normal display, night mode, reading mode... but i still think what is available is perfect
  5. Aniruddha Deshpande Froyo Jan 1, 2018
    airplane mode gaming mode are also options for the slider...like its really a mess to go in quick access menu and start gaming mode while slider can do it easily
  6. Ghenox Donut Jan 2, 2018
    Ghenox, Jan 2, 2018 :
    if we have 3 modes in alert side.. how about we can costumize or more choices to change the 3 modes in alert side..
  7. Pranav2808 Cupcake Jan 2, 2018
  8. Kaushik89 Cupcake Jan 2, 2018
    Kaushik89, Jan 2, 2018 :
    I would like to have ring-vibration-silent....
    it will be a lot better experience if this small change is made!!!!!
  9. Kaushik89 Cupcake Jan 2, 2018
    then just set the gaming DND for specific apps as I did!!
    no need to even go to quick settings or elsewhere!!!
  10. harry_db Gingerbread Jan 5, 2018
    harry_db, Jan 5, 2018 :
    make it fully adjustable, so users can make their own template based on their requirement.
  11. nickhell Honeycomb Jan 5, 2018
    nickhell, Jan 5, 2018 :
    For me the perfect solution is:
    scheduled dnd with calendar integration and ability to customize alert slider buttons
    If scheduled dnd is off then regular alert slider behavior
    stephanejap likes this.
  12. RedVoodoochild Cupcake Jan 9, 2018
    RedVoodoochild, Jan 9, 2018 :
    Hi.
    Excuse my poor english.
    I'm a new owner of the 5t, and new to OnePlus. I'm come back from a nexus 5 and a Xiaomi MI5s. The two with LineageOs.
    A missing feature on OOS that I'd appreciate on lineageOS : The "system profiles".
    It will be great, that the AlertSlider, were a shortcut at this system profiles what we could configure has we want.
    Of course, OnePlus must implement this feature on the rom, first.. :p
    Paco
  13. X1512224223026 Froyo Jan 9, 2018
  14. megarinho Donut Jan 14, 2018
    megarinho, Jan 14, 2018 :
    As always I think that we should have the ability to fully customize the alert slider, so I chose to have the two options available and a third one to completely disable it and use Stock Android's settings.
  15. Prashant kumar sangwan Gingerbread Jan 15, 2018
    D1508795193136 likes this.
  16. G_Sebastiaan_Borrezee_aV Cupcake Jan 15, 2018
  17. Bautista Peñoñori Cupcake Jan 17, 2018
    Bautista Peñoñori, Jan 17, 2018 :
    hi!
    I think Ring /Vibrate/Total Silence is the best option. but it would be also great if we have the ability to fully customize these 3 options!
  18. spooksman Cupcake Jan 17, 2018
    spooksman, Jan 17, 2018 :
    I need the automatic functionality returned so I can set quit times and thing like that from a schedule.
    The slider is good, but you have to remember at night...
  19. spooksman Cupcake Jan 17, 2018
    quiet of course
  20. Sanyatoneplus Froyo Jan 18, 2018
    Sanyatoneplus, Jan 18, 2018 :
    The ability to customise the setting for each of the alert, for example I want to have vibration in silent mode but can't do that now. Similarly in do no disturb mode, ability to select a type of tone for selected alerts only.
