270
[Survey] How should we revamp Alert Slider?
  1. Hussaini Abdul Donut Mar 30, 2018
    dalmia09 likes this.
  2. Kishore_Priyadharsan Froyo Mar 30, 2018
  3. GaryCoates Froyo Mar 31, 2018
    GaryCoates, Mar 31, 2018 :
    Always been a fan of the 'profile' idea. Creating 3 profiles, and assigning to each mode on the switch.
    Allowing for more than audio customisations. For example, creating a 'bed' profile which as well as silencing and turning off vibrate, turns on night mode.
    Joel B and juanrugge like this.
  4. Televizoralb Cupcake Apr 1, 2018
  5. jm_paulin Froyo Apr 3, 2018
    jm_paulin, Apr 3, 2018 :
    1. Keep the slider. This is the best option to make your phone go silent when you just realised you forgot to switch it off, like library, cinéma, meeting...
    2. The vanilla oreo DND software is doing a pretty good job with DND time and stuff. I don't use the DND position because I mostly forgot when I go bed. This is where the software timer helps.
    Oh, and bonus points, you keep your DND settings when you move from another brand, and can still change them, unlike when I moved from OPO to OP3 and couldn't cancel/change my migrated DND settings...
  6. hims.rajput Donut Apr 5, 2018
  7. johnedavisii Cupcake Apr 6, 2018
    johnedavisii, Apr 6, 2018 :
    maybe an option to completely disable it so we can stop accidentally turn silent on while putting it in our pockets?
    Joel B likes this.
  8. palc Ice Cream Sandwich Apr 7, 2018
  9. JohnCarlyle Froyo May 19, 2018
    JohnCarlyle, May 19, 2018 :
    THREE options:
    Top - Silent
    Middle - Vibrate
    Bottom - Ring
    Just like the volume up/down buttons worked pre-Lollipop until Google decided to break it.
    Looks like this has already been done on the OnePlus 6, I'm rather hoping the 5/5T also get this update to the alert slider too.
    pictory likes this.
  10. siamer Gingerbread May 20, 2018
    siamer, May 20, 2018 :
    I'm using a lot slider. when in work always sliding to vibration and is great... never didn't use silent mode (op3 user)
  11. Prashant kumar sangwan Gingerbread May 22, 2018
  12. artloverjv Ice Cream Sandwich May 22, 2018
    artloverjv, May 22, 2018 :
    I think surveys are a great way to know what the Community wants from OnePlus devices. More people can take part in these compared to the Votes via posts. Keep these Surveys coming guys.
    About the Alert Slider, I think I like it the way it is right now and I use it multiple times during the day.However, I don't mind if any other customizations can be made to the slider, while keeping the current functions intact.
  13. BiswajitB Gingerbread May 22, 2018
    BiswajitB, May 22, 2018 :
    I would also like a customable switch. Maybe you can remove the Hardware Switch and let the user set the requirements from the settings itself
  14. PTuT Jelly Bean May 22, 2018
    PTuT, May 22, 2018 :
    I would keep the hardware switch, it's something unique to OP like its signature but make it fully customizable so user cwn decide how to use it.
  15. Sarang Manzoor Eclair May 22, 2018
    Sarang Manzoor, May 22, 2018 :
    It should be customizeable when we press it down or up, not thrice.
    Pressing Up, should open up menu with user interaction to select from option, which already are available with current Alert Slider. I means all options should be like this way.
    options should be
    1) Silent with vibrations (increasing ring)
    2) Vibrations only (No Ring)
    3) Silent without vibrations
    4) Loud or Normal
    6) Custom (User's Choice)
  16. PTuT Jelly Bean May 26, 2018
    PTuT, May 26, 2018 :
    Some time went after the survey was announced but I didn't hear anything about any changes or implementations payh. It would be nice to see some follow up.
  17. Circazm Cupcake May 30, 2018
  18. elanglois Lollipop May 31, 2018
  19. elanglois Lollipop May 31, 2018
    elanglois, May 31, 2018 :
    Note that each option let's you configure each switch position to your liking as well, and you still have scheduled DND for specific times, calendar events, etc
  20. elanglois Lollipop May 31, 2018
    The whole point of the slider is that you don't have to turn your screen on
    Sarang Manzoor likes this.
