30
[SURVEY INSIDE] End of Android 11 Open Beta release cycle for OnePlus 8T : OxygenOS 11 Open Beta 7
  1. #41
  2. Antonygeorge99
    Honeycomb Jul 28, 2021
    Antonygeorge99 , via OnePlus 8T , Jul 28, 2021 :
    Thank you for being atleast a bit supportive. The team will try to improve based on feedbacks
    #42
  3. Antonygeorge99
    It could based on what application you use. but normally it doesn't exceed 34-35. It depends on how long you use too.
    #43
  4. PoTeTo
    Eclair Jul 28, 2021
    PoTeTo , via OnePlus 8T , Jul 28, 2021 :
    But my phone alwsys hot.. when charging this phone hot too 🥲
    #44
  5. Antonygeorge99
    See brother, Google provides call recording feature. Now as far as using OnePlus dialer all phones from 8T can only use Google's communication suite a deal has been made. The team found it more convenient and better for consumers because, the support directly comes from Google and newer features could roll out to users. There are some interesting features coming to google communications. We also did mention this in the advertisement for 8T too.
    #45
    Nags1817 likes this.
  6. Antonygeorge99
    Charging Yes it will become hot. Please do check what is your temperature range and do feel free to send it a powerlog to our feedback team. Logs and additional tools can be accessed by using *#800#
    #46
  7. PoTeTo
    Eclair Jul 28, 2021
    Ouhhhh ok.. tq 👏
    #47
  8. Antonygeorge99
    #48
  9. aedan83
    Cupcake Jul 28, 2021
    #49
  10. hipy_10
    Donut Jul 28, 2021
    hipy_10 , Jul 28, 2021 :
    It does not detect the file in local improvement, I changed the .jar to .zip and it still does not appear, does someone else know?
    #50
  11. Sheikh_Rafiq_
    Gingerbread Jul 28, 2021
    Sheikh_Rafiq_ , Jul 28, 2021 :
    Any news for stable itz been more than a month and is there any news that are we getting bit emoji AOD on stable @abdul will you revert?
    #51
  12. amilcar29
    amilcar29 , Jul 28, 2021 :
    I already know why you don't recognize it, the name of the EU version is "OnePlus8Oxygen_15.O.37_OTA_0370_all", while in the INDIA and GLOBAL versions it has this name "OnePlus8TOxygen_15.I.25_OTA_0250_all", now I don't know if we changed the name to "OnePlus8TOxygen_15.I.25_OTA_0250_all" or put version 8 by mistake in the 8T
    #52
    the_o2 likes this.
  13. Vishnuduttsidhu
    Vishnuduttsidhu , via OnePlus 8T , Jul 28, 2021 :
    How you install... Please advise
    #53
  14. eloimuns
    #54
    amilcar29 likes this.
  15. Caomhin
    OnePlus 9 Series Expert Community Expert Jul 28, 2021
    Caomhin , via OnePlus 9 Pro , Jul 28, 2021 :
    Please remove your personal contact details, this is a public forum and your details can be used to spam you.
    Download the software build for your Region from the first post at the top of the thread.
    ⚡Please back up your data before flashing your device.⚡
    After downloading, If the file ends in .jar, edit the filename so it ends in .zip
    Ensure you move the file to your out of any folders and into the main storage
    After the .zip file is copied to your phone, go to 'Settings' - 'system update', click the 'settings' icon on the top right corner, choose 'Local upgrade', find the .zip file and click on 'Install' to confirm.
    The update takes about a minute (depending upon the file size), once done reboot your device to boot into the Stable Oxygen OS.
    #55
  16. dsmonteiro
    Community Consultant Staff Member Jul 28, 2021
    dsmonteiro , Jul 28, 2021 :
    Olá Amilcar,
    Thank you for raising this. We already edited the link.
    #56
    the_o2, Caomhin and amilcar29 like this.
  17. YassGomez
    YassGomez , Jul 28, 2021 :
    If I'm rooted, can I update with local upgrade and install Magisk on inactive Slot ?
    #57
  18. Muthusubramanium
    Donut Jul 28, 2021
    #58
    sourink likes this.
  19. Caomhin
    You would have to install the package through TWRP, as its a specific rollback package and it will wipe your data, so you will need to Backup your Data, you can then setup Magisk the same as you had it previously.
    #59
  20. Antonygeorge99
    Have to placed the folder in the root folder as in not inside any folder ?
    #60
