86
[SURVEY INSIDE] Oxygen OS Open Beta 3 for the OnePlus 7T and OnePlus 7T Pro
  1. D1580145154835
    Cupcake May 9, 2020
    D1580145154835 , via OnePlus 7T , May 9, 2020 :
    how can we download if we are switching from stable to open beta
  2. gionny.26
    Cupcake May 9, 2020
    gionny.26 , via OnePlus 7T , May 9, 2020 :
    Hi there everyone! I was wondering if anyone experienced this issue. So basically after the OB3 update on my OnePlus 7t the icons on my insta and on my Snapchat look pixelated.. I run beta versions on both apps and I'm running the latest beta versions. Also I sent a bug report to Instagram and OnePlus and I've updated insta this morning but nothing's changed.
    Niek Kant and Fatih Aşkın like this.
  3. Advvinay
    Gingerbread May 9, 2020
  4. asif_eqbal
    Donut May 9, 2020
  5. Rajput_Sahab
    Froyo May 9, 2020
    asif_eqbal likes this.
  6. tepetidis kostas
  7. tepetidis kostas
    tepetidis kostas , via OnePlus 7T , May 9, 2020 :
    look, if you use contactless payment, it’s better to have a stable one, and if you want to receive all the latest first, then beta firmware.
  8. OnePlusMenace
    Cupcake May 9, 2020
    OnePlusMenace , May 9, 2020 :
    Awesome! Was waiting for the ringtone features to come to OP since I moved away from Galaxy S8. Very helpful indeed!
    iamabhijeetpanda likes this.
  9. Rajat_arora_
    umartariq likes this.
  10. hamvaspeter
    Eclair May 9, 2020
    hamvaspeter , via OnePlus 7T Pro , May 9, 2020 :
    I had to install the full zip via OTA, incremental showed me a probem with the install.
    Telenor Hungary VoLTE is not supported. I had to activate it again...
    Build prop has no ro.build.eu true. I was on Beta2 Eu.
  11. Merihy
    Cupcake May 9, 2020
    Merihy , via OnePlus 7T , May 9, 2020 :
    hi, is there any bug or unstable condition for nfc payments?
    did you face any problem about nfc?
  12. cristianos1304
    Cupcake May 9, 2020
    cristianos1304 , May 9, 2020 :
    I have same issue do you have root? Any magisk modules? I'm just looking for a solution before i go back to beta 2 or go stable o_O:oops:
  13. tepetidis kostas
    Hi, yes, at the moment I have a problem on 7t (payment applications are not connected with contactless payment), it is thrown out of the application, but when there was stable firmware everything worked for me perfectly.
  14. mani0283
    Eclair May 9, 2020
  15. rahulkhajanchi
    Cupcake May 9, 2020
  16. li0r
    Donut May 9, 2020
    li0r , May 9, 2020 :
    Hi , i'm in Beta 3 and not see In Wi-Fi and Network setting , "OnePlus Roaming Features" option how it can be?
  17. pathofwisdom07
    Donut May 9, 2020
    Kartikk76 and ejaquino like this.
  18. iamrohitparmar
    Froyo May 9, 2020
  19. Pt25
    Eclair May 9, 2020
    Pt25 , via OnePlus 7T , May 9, 2020 :
    what? some are saying beta 2 was draining battery fast.
