86
[SURVEY INSIDE] Oxygen OS Open Beta 3 for the OnePlus 7T and OnePlus 7T Pro
  1. mani0283
    Eclair May 9, 2020
    mani0283 , via OnePlus 7T , May 9, 2020 :
    battery drain fast after beta 3 update
    D H V S Sastry likes this.
  2. Pt25
    Eclair May 9, 2020
    Pt25 , via OnePlus 7T , May 9, 2020 :
    bro you're using phone on dual SIM or single SIM?
  3. li0r
    Donut May 9, 2020
    li0r , May 9, 2020 :
    i have dual sim , but using only one sim
    as i remembet on oneplus 3 beta this option was there
    but here on op7t i don't see it
  4. ejaquino
    Eclair May 9, 2020
    Kethrildur likes this.
  5. ejaquino
    Eclair May 9, 2020
    PriyeshPatil likes this.
  6. chiraggohil
    Gingerbread May 9, 2020
    chiraggohil , via OnePlus 7T , May 9, 2020 :
    I update beta3,. may i know why wifi icon after of volte icon? same as also vibration icons its also after volte???
    and no indented wife working i mean arrow up and down?? i mean in internet work arrow which you provide in data mode ( 2g ,3g,4g)
    i think so you forget it. i request you please make identify wifi running and showing arrow. for you info another screen shot attached. which is data pack running and its in arrow while internet working up and down like that
    - i suggest many times i missing notification features.
    you may provide it. in front camera notch area where curve is available.
    you make that curve notification light ( multiple colours light) Samsung 30 series i think ,given this type features. but samsung provide while notification only you may give all type notification light ( blue, yellow,red, white, pink etc)
    - clear apps missing. lots of catches & junk created. so i hope one plus give inbuilt app to clean it.
    - missing one plus app which can open excel , word , ppt. file.
    because currently we depend upon 3rd part app.
    - you may add health app. because now day people very caring self so they all wants health app. you may be check samsung provide health app inbuilt .
    - you need to upgrade slow motion. because its not work effectively, lines coming while light area comes.
    Prathzz likes this.
  7. absolut_unyt
    Cupcake May 9, 2020
    absolut_unyt , via OnePlus 7T , May 9, 2020 :
    same here bro
    Prathzz likes this.
  8. Prathzz
    Eclair May 9, 2020
  9. Prathzz
    Eclair May 9, 2020
  10. ejaquino
    Eclair May 9, 2020
    asif_eqbal, Kethrildur and ananyr like this.
  11. iamabhijeetpanda
    Honeycomb May 9, 2020
    iamabhijeetpanda , via OnePlus 7T , May 9, 2020 :
    bro actually I don't know but see here is the option m
    li0r likes this.
  12. iamabhijeetpanda
    can you share proper screenshots..
  13. tepetidis kostas
  14. rushibhatt
  15. ananyr
  16. Tausif.Shaikh786
    Eclair May 9, 2020
    Tausif.Shaikh786 , via OnePlus 7T , May 9, 2020 :
    Does the Optimised charging feature only works if alarm is set or DND schedule has been setup ?
    I got the notification yesterday when charging reached 80% but not today. The only difference was DND was scheduled before but not today.
  17. Boubaker01
  18. Piyushanni
    Piyushanni , via OnePlus 7T , May 9, 2020 :
    It was taking time in Stable also. Slightly delay, only setting font shows up for a second then rest of the entry are visible.
    Happened on Stable update too 🙁
    Prathzz likes this.
  19. Piyushanni
    Suggest those feature in feedback section bro 🙂
  20. D1542455291130
    Cupcake May 10, 2020
