86
[SURVEY INSIDE] Oxygen OS Open Beta 3 for the OnePlus 7T and OnePlus 7T Pro
  1. Piyushanni
    Gingerbread May 7, 2020
    Piyushanni , via OnePlus 7T , May 7, 2020 :
    I am on the latest stable how to install beta. Downloaded open beta 2 from the link given in the discription. In local upgrade its showing error "The version you have selected package is lower...."
  2. Piyushanni
  3. afogel
    Froyo May 7, 2020
    afogel , via OnePlus 7T , May 7, 2020 :
    I noticed incredible lag while scrolling in Chrome or YouTube for instance. try to scroll slowly. it lags the hell out of my device. dunno what is causing this, will try to wipe cache
  4. rahim_roycz
    Donut May 7, 2020
    rahim_roycz , via OnePlus 7T , May 7, 2020 :
    bro u need to update beta 3? from beta 2?..
  5. rahim_roycz
    Donut May 7, 2020
  6. pmanaktala
    Froyo May 7, 2020
    pmanaktala , via OnePlus 7T , May 7, 2020 :
    this won't work, as the stable build number > ob2 build number so it won't allow you to install
    Download the FULL ob3 from oxygen updater (you might need to enable beta builds in the settings) and then you can flash that using mobile software update section directly without losing any data
  7. pmanaktala
    Froyo May 7, 2020
  8. ananyr
    Honeycomb May 7, 2020
  9. pmanaktala
    Froyo May 7, 2020
    Anyone able to get the dirt on lense notification work?
    Things i tried but no luck
    1. Tried touching the camera with butter/oily fingers.(Happens to me sometimes when i eat and use phone so i guess was a good way to test) but no luck even though camera was hazy.
    2. Tried putting a bit of toothpaste on camera(yeah i was that desperate to check how it will work), but no help
    May be the feature is broken considering its just OB.
    May be it has to be turned on somewhere (went through settings thought, no luck)
    If anyone was able to/might get a notification please reply with a screenshot here.
  10. pmanaktala
    Froyo May 7, 2020
    ejaquino
    Live Caption now has a dedicated button on the volume panel. You can now also simultaneously use both wifi and data for a faster connection. In Open Beta 2, you can only do it when downloading something.​
    Is the live caption is it the same as instant translation?
    SahanCZ likes this.
  11. Aviroop96
    Froyo May 7, 2020
    Aviroop96 , via OnePlus 7T , May 7, 2020 :
    STOP SHOUTING
  12. KeeBaud
    Froyo May 7, 2020
    KeeBaud , May 7, 2020 :
    Airplane mode is supposed to turn off all radio devices in the phone, including WiFi. It's called airplane mode because you're not supposed to have any radio devices turned on in an airplane.
    What you're asking for defeats the whole purpose of airplane mode.
    It would be better to request a data only (no cellular) mode if that's what you're looking for.
    p.pavljasevic and Kethrildur like this.
  13. iamabhijeetpanda
  14. Q1572037092872
  15. dalekrebs
    Eclair May 7, 2020
    dalekrebs , via OnePlus 7T , May 7, 2020 :
    contrary...it works perfectly. my phone charges to 80% near bedtime and then finishes the 100% charge by the time I get up at 6.15 in morning.
    Adarsh792000 likes this.
  16. Elshafey
    Cupcake May 7, 2020
  17. dalekrebs
    Eclair May 8, 2020
    dalekrebs , via OnePlus 7T , May 8, 2020 :
    installed 2Beta3 and it's doing me well. the Benchmarks are mixed... Single-core results up 20 pts but multi-core is down by 100 pts.
    SahanCZ likes this.
  18. bmwfire
    Eclair May 8, 2020
    bmwfire , via OnePlus 7T , May 8, 2020 :
    After Beta 3 update i have noticed :
    *While gaming the 7T is getting more hot than before playing the same game.
    *The signal of my mobile network is lower than before.
    Hope we getting more often updates ! Thank you OnePlus Team
    Niek Kant and OmarRolon like this.
  19. Piyushanni
    Gingerbread May 8, 2020
    Piyushanni , via OnePlus 7T , May 8, 2020 :
    I am able to install open Beta 3 from Stable.
    I used XDA site and download the full Zip of Beta 3 and flashed it from local upgrade.
    Instruction in this forum is not clear many ppl will download the Open Beta 2 from the link they have provided and waste their data.
    Poor instruction provided in this thread and the same information is given in Open Beta 2 thread 😕
    rajat0409 and L1519865420469 like this.
