84
[SURVEY INSIDE] Oxygen OS Open Beta 4 for the OnePlus 7T and OnePlus 7T Pro
  1. dancass
    Cupcake May 22, 2020
    dancass , May 22, 2020 :
    lol that's not what I was asking. are you a beta tester for the OnePlus launcher ?
  2. a.abdelfatah
  3. dancass
  4. a.abdelfatah
  5. Olley85
    Eclair May 22, 2020
  6. ZakooosNS
    Eclair May 22, 2020
    ZakooosNS , via OnePlus 7T Pro , May 22, 2020 :
    I use EU Beta (OB1 or OB2). Why there are no updates anymore?
    It seems that Oneplus merged EU and global beta builds to global only! Move to global simply by flashing a global build. See
    G_Micha_El_JgvU likes this.
  7. Madhan8
    Froyo May 22, 2020
    Madhan8 , via OnePlus 7T , May 22, 2020 :
    Hi
    I tried but it's showing Beta 3 updated only... already I'm using beta 3
    please find the image
  8. Prathzz
    Eclair May 22, 2020
  9. Olley85
    Eclair May 22, 2020
    Shareef Mahaboob and ZakooosNS like this.
  10. kcajith
    kcajith , via OnePlus 7T , May 22, 2020 :
    Is there a way to downgrade from Open Beta-4 to Open Beta-3 via dirty flash? Don't want the Hassel of full wipe and flashing, instead just want to manually flash open beta 3 on top of open beta 4. Will this work??
  11. vaduganathan
  12. CWOoi
    Donut May 22, 2020
    thesign likes this.
  13. KathiravanJLR
    Gingerbread May 22, 2020
  14. scorpion161986
    Froyo May 22, 2020
  15. R1ch4t likes this.
  16. R1ch4t likes this.
  17. Last edited: May 22, 2020
  18. thesign
    thesign , via OnePlus 7T Glacier Blue , May 22, 2020 :
    yep! drain seems just a bit less when compared to stable.
    but one big change i found is my phone is running more colder than usual.
    isn't heating up as much either.
    CWOoi likes this.
  19. scorpion161986
    Froyo May 22, 2020
