84
[SURVEY INSIDE] Oxygen OS Open Beta 4 for the OnePlus 7T and OnePlus 7T Pro
  1. rHITkM
    Honeycomb Jun 1, 2020
    rHITkM , Jun 1, 2020 :
    post no 1035
    and it has been answered many times in this thread. try searching.[e]1f44d[/e]
  2. Fixxer
    Gingerbread Jun 1, 2020
  3. rHITkM
    ok.good[e]1f44d[/e]
  4. Fixxer
    Fixxer , via OnePlus 7T Pro , Jun 1, 2020 :
    It has been asked multiple times about the freeform windows and all I can get out of this thread is to enable freeform windows in developer options and "kind" advices to look it up in the thread. Wow. As I've said the first 30 pages at least doesn't mention what to do after. If you wanna really help, you could have told us the page number where it is written not to read all and find out afterwards it's just the developer option mentioned.
    OK, so after you enabled the developer option, check your recent app list, go to a specific recently opened up you wish to freeform and long press it until a scroll list of options will pup up, including the freeform one.
    More details in the link below.
    https://www.droidviews.com/freeform-windows-android-10/
  5. gurusiva26
    Cupcake Jun 1, 2020
  6. VB1
    VB1 , Jun 1, 2020 :
    The dynamic wallpapers you are trying to use is of OP8 series. Have you updated the OP Wallpaper resources app? If yes then reboot your device & then try to set the wallpaper.
  7. Mazharapps , via OnePlus 7T Pro McLaren Edition , Jun 1, 2020 :
    not happening with me.
    I updated it's, it's happened. Later I downloaded full package & upgraded. no such issue.
    even I did a factory reset, didn't find this type of issue.
  8. afogel
    Froyo Jun 1, 2020
    afogel , via OnePlus 7T , Jun 1, 2020 :
    and this is mine. lately, in the last couple of days, I can't get through a day with only 1-2hrs of screen usage... dunno what's happening. will do a factory reset, I'm just lazy *** to backup my apps that are not from the play store and go through all the hassle to reinstall them.
  9. iamsiddhant_t
    Froyo Jun 1, 2020
    iamsiddhant_t , via OnePlus 7T , Jun 1, 2020 :
    Even dark mode isn't helping me.
  10. gurusiva26
    Cupcake Jun 2, 2020
    gurusiva26 , Jun 2, 2020 :
    thanks bro
  11. gurusiva26
    Cupcake Jun 2, 2020
    customisation is not responding bro
    how can we fix it
  12. ronabelleico
    Cupcake Jun 2, 2020
  13. Chaudharykartik
    Cupcake Jun 2, 2020
    Chaudharykartik , via OnePlus 7T , Jun 2, 2020 :
    Hi there!
    I have installed OOS 10.3.3 (India) for my 7T and when I try to install Open Beta 4, it says that this upgrade is of a lower version. Please help me resolve this issue. Also, what is the frequency of OnePlus rolling out beta updates, so that I can wait for Open Beta 5 to install on my device?
  14. Chaudharykartik
    Cupcake Jun 2, 2020
    Hi there!
  15. ASCHENTE_V
    Jelly Bean Jun 2, 2020
    ASCHENTE_V , Jun 2, 2020 :
    https://forums.oneplus.com/threads/faq-oneplus-7t-oxygenos-beta-stable-update-guide.1229015/
    Open beta releases are about twice a month.
    G1581664092841 likes this.
  16. Fatih Aşkın
    Gingerbread Jun 2, 2020
  17. rHITkM
    Honeycomb Jun 2, 2020
    rHITkM , Jun 2, 2020 :
    reset your phone , but first take backup of your data.
