84
[SURVEY INSIDE] Oxygen OS Open Beta 4 for the OnePlus 7T and OnePlus 7T Pro
  1. N1580388597241
    Froyo Jun 2, 2020
    D1584704000898 likes this.
  2. Donald Nice
    Honeycomb Jun 2, 2020
    Donald Nice , Jun 2, 2020 :
    Please read FAQ, #11
  3. rHITkM.
    rHITkM. , Jun 2, 2020 :
    Go to recents > tap and hold tha card > choose freeform window.
    ONLY FEW APP COMPATIBLE NOW LIKE CHROME, PLAY STORE, GOOGLE, ETC.
    IMPORTANT: if some apps crashes after choosing freeform window like Twitter and refuse to open , then disable the option in developer mode and restart and then the same app will open without any problem.
    Fixxer likes this.
  4. Bobby.K
    Donut Jun 3, 2020
  5. AbhiMatanhelia
    Cupcake Jun 3, 2020
    AbhiMatanhelia , Jun 3, 2020 :
    some apps icon in youtube, instagram and twitter are appearing blurry as if they are on low resolution.
  6. JelleZon
    OnePlus Accessory Tester Jun 3, 2020
    JelleZon , Jun 3, 2020 :
    yes, have the same issu.
    AbhiMatanhelia likes this.
  7. Dhanoa38
    Froyo Jun 3, 2020
    bpokra likes this.
  8. rHITkM.
    Honeycomb Jun 3, 2020
  9. rHITkM.
    rHITkM. , Jun 3, 2020 :
    did you download the update package through third party app or via OTA update .
  10. bpokra
    Donut Jun 3, 2020
  11. Dhanoa38
    Froyo Jun 3, 2020
  12. bpokra
    Donut Jun 3, 2020
  13. rHITkM.
    this looks like launcher related issue. Do you have the updated launcher version from the Play Store?
    bpokra likes this.
  14. bpokra
    Donut Jun 3, 2020
  15. rHITkM.
    try uninstalling the updates for launcher and then reinstall the new version from the Play store. let me know if that helps.
  16. bpokra
    Donut Jun 3, 2020
    Dhanoa38 likes this.
  17. rHITkM.
    I have the beta version too but I have not faced such problems.
    if stable version working for you then better stay on that .
  18. N1580388597241
    Froyo Jun 3, 2020
  19. Fixxer
    Gingerbread Jun 3, 2020
    Fixxer , via OnePlus 7T Pro , Jun 3, 2020 :
    I have complained about slow charging before and I did sent logs to OnePlus and currently waiting for their reply.
    It seems like during charging my cpu load is very high and the phone is heating up, although the phone is idle and I'm not playing or using it meantime. So probably the charging speed is the same, but the phone is consuming power, having the cpu at max load, translating in to higher time periods while the phone needs to stay plugged in. After I unplug it, cpu load drops to normal behavior.
    Anyone else with this issue? I think is really harmful to have such high temperatures and the cpu load to stay at 100% especially while charging and heating.
    Please find below a graph of my cpu load while charging.
