84
[SURVEY INSIDE] Oxygen OS Open Beta 4 for the OnePlus 7T and OnePlus 7T Pro
  1. ananyr
    Honeycomb Jun 4, 2020
    ananyr , via OnePlus 7T , Jun 4, 2020 :
    lol ... you are funny [e]1f602[/e][e]1f602[/e][e]1f602[/e]
  2. ananyr
    you 2
  3. Fixxer
    Gingerbread Jun 4, 2020
    Fixxer , via OnePlus 7T Pro , Jun 4, 2020 :
    afogel
    I did clean it a few times these days. also I deleted storage of Google Play Services and then again, cleared cache.​
    So, it seems I had an app which was causing high cpu loads and longer charging times, since it was an alarm app that I used while charging only.
    Battery Full Low Alarm was the app, I recommend avoiding it.
    CPU was getting hot, stood at 90%+ load during charging, higher temps and therefore slower charging speeds.
    Case solved
    All feedback was sent to OnePlus also, before they came with additional input.
    afogel likes this.
  4. achenenene_2016
    Cupcake Jun 4, 2020
    achenenene_2016 , via OnePlus 7T , Jun 4, 2020 :
    Hi guys!
    It has been a few days that when i am inside on App and i make the gesture to go back home screem, the phone doesn't do It as always, the animation is different.
    It makes a similar animation to when i install a third-party "Launcher" and It doesn't perform the same animation as with original Launcher.
    Has anyone detectes this on their phones?
    i have rebooted, i have cleaned system Cache and Launcher cache.
    thanks
    Regards.
  5. Fixxer
    Neitred
    So many problems with battery, things not working, heating while charging. I don't understand why I'm not having any of these problems. So somewhere it goes wrong. [e]1f609[/e]​
    Don't speak too soon [e]1f61d[/e]
    Anyhow, as stated, in my case I've found the reason. There is always a third party involved and usually those things aren't being caused by the OS.
    Neitred and Donald Nice like this.
  6. Neitred , via OnePlus 7T Pro McLaren Edition , Jun 4, 2020 :
    That is onest. Wish more people first find out why these thing happen.
    Fixxer likes this.
  7. ananyr
    battery drain issue ... what to do
  8. swathikrishnavemula
    Gingerbread Jun 5, 2020
    swathikrishnavemula , via OnePlus 7T , Jun 5, 2020 :
    what is the use of this? can you please elaborate.
  9. beanpolebiker
    Neitred likes this.
  10. ananyr
    Honeycomb Jun 5, 2020
  11. MartinRo
  12. M1573370419318 likes this.
  13. Neitred likes this.
  14. rahulhere_
    Donut Jun 5, 2020
  15. hsy78
    Froyo Jun 5, 2020
    rahulhere_ likes this.
  16. Q1572037092872
    Q1572037092872 , Jun 5, 2020 :
    With the Beta 4 Global, the Lte reception is poor, few bars. Is that also the case in Beta 4 EU?
